Cossie , fuel filter question???? help
Old Mar 7, 2007 | 09:31 PM
rabmc's Avatar
rabmc
Default Cossie , fuel filter question???? help
About to fit my 044 pump on my 3dr cosworth guys BUT on getting under the car to do so , noticed my fuel fulter is a cheapo little fuel filter , the clear ones you would get in a nova or something
Can i change back easily to the proper one >? though it should be the "can" type and not with jubilee clips at each end ? any help appreciated , on why i would have this , surely its not normal ????
Old Mar 7, 2007 | 09:33 PM
rapidcossie's Avatar
rapidcossie
Sounds like someone has chopped and changed the fuel lines a bit mate...
best get a look under jonnys car and try and copy that...
Thats if his is normal
Old Mar 7, 2007 | 09:35 PM
Jasesapphy's Avatar
Jasesapphy
uses banjos, buy a filter from ford, go to pirtecks or hypehose they do adapters that will fit, couple jubliee clips and some fuel injection pipe, job jobbed
Old Mar 7, 2007 | 09:42 PM
rabmc's Avatar
rabmc
Cool troops , am on to it
Looks suspect to me ,l`L getting this car right slowly but surely
Old Mar 7, 2007 | 09:43 PM
rapidcossie
sounds like the last owner liked a bodge Rab
Old Mar 7, 2007 | 09:44 PM
rabmc's Avatar
rabmc
The last owner was a cock euan , plain and simple !
This is the last of his devious work im sure of it
Old Mar 7, 2007 | 09:45 PM
rapidcossie
best to get this changed before its checked on the rollers as wee things like this can effect fuel pressure.
Old Mar 7, 2007 | 09:47 PM
rabmc's Avatar
rabmc
At a bit of a crossroads euan have these light blues here , but cars running at moment with the greens , going to get this pump in and get her to ava to set up , but think its a waste if im putting these blues in it but need a chip etc , would ava hook me up with what i need for the blues ?? want it better and rolling roaded for crail , but maybe doing the blues is goiung to set me back time and effort and money for the sake of a month or so , hope this makes sense
Old Mar 7, 2007 | 09:49 PM
rapidcossie
what turbo do you have Rab?
Do you want to really push the engine to the point where you will max the greens? (300 ish ATW)
AVA can sort you out with what ever you need Rab
Old Mar 7, 2007 | 09:53 PM
rabmc's Avatar
rabmc
The hing is got these blues for a bargain so kind of want to use them and heard there slightly better all round , anyway 300atw max for me , anything over 270ish i`d be chuffed with , probably , again im running 13psi just now and dont ever nail it , and need to get this thing squating !
Old Mar 7, 2007 | 09:54 PM
col cos1's Avatar
col cos1
rab get a filter from graham goode pretty reasonable and genuine ford and always therenext day
Old Mar 7, 2007 | 09:56 PM
col cos1's Avatar
col cos1
a set up will only cost you an hour on rollers hopefully mate Ł60,at least peace of mind for fueling,misfires etc for crail
rapidcossie
dont bother with the blues at the moment then Rab as 280 is no probs for the greens.
Just get to rollers and get it set up the blues just complicate things and they arent really needed at this spec level.
25 psi will feel ALOT quicker than 13
Old Mar 7, 2007 | 10:14 PM
rabmc's Avatar
rabmc
Hope so mate , will do that then , get the greens going to see whats going on
Old Mar 7, 2007 | 10:17 PM
rapidcossie
no reason why it cant make 270-300 ATW on your spec if the engine and turbo are healthy
Old Mar 7, 2007 | 10:38 PM
Stu @ M Developments's Avatar
PassionFords Creator
Default Re: Cossie , fuel filter question???? help
Surely not, take a picture man!!
How the hell has that stood up to 4.5 - 5bar fuel pressure!!
Old Mar 8, 2007 | 05:32 PM
rabmc's Avatar
rabmc
Stu this is true ,iL get a picture , was pretty shocked when i seen it as well , dont know the science behind it all but knew it was`nt what i was suppose to be seeing
Why would someone do this ???
Old Mar 8, 2007 | 05:41 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
never
really
cossirob
Aug 29, 2015 03:23 PM
kosienutter
31
Aug 22, 2015 09:55 AM
3doorcozmess
Aug 21, 2015 11:17 AM
ekjim
Aug 17, 2015 08:57 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
