Software advise
Old Mar 7, 2007 | 08:19 PM
dmcnulty's Avatar
dmcnulty
Default Software advise
I have a folder in my desktop that xp wont let me delete. It just contains some downloads, it keep saying part is missing Is there any software about to delete this folder
Old Mar 7, 2007 | 08:23 PM
AndyBrew's Avatar
AndyBrew
from a dos prompt type
Start -> Run -> cmd [enter]
type
chkdsk c: /F
asuming c: is your hard disk drive that should go through all your files and folders and fix any issues with corruption you should then be able to delete your directory
Old Mar 8, 2007 | 12:05 AM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
If thats too hard download Unlocker
http://ccollomb.free.fr/unlocker/
Old Mar 8, 2007 | 07:46 AM
JohnnyB's Avatar
JohnnyB
safe mode,
Hit del
Old Mar 8, 2007 | 07:52 AM
patchST's Avatar
patchST
First thing to do is to make sure that any download programs are closed usually they lock the folder when running and then try and delete the folder.
Then if not go to start - run type cmd
in there you need to get to the desktop folder you'll need to type cd desktop
then type dir /x there you'll get a out put like this
C:\Documents and Settings\Administrator>dir /x
Volume in drive C has no label.
Volume Serial Number is ACB1-BFC4
Directory of C:\Documents and Settings\Administrator
18/12/2006 12:56 <DIR> .
18/12/2006 12:56 <DIR> ..
25/07/2006 09:15 <DIR> HOUSEC~1 .housecall
30/01/2007 23:47 <DIR> LIMEWI~1 .limewire
12/01/2007 08:40 <DIR> SPAMAT~1 .spamato4thunderbird
18/12/2006 12:56 121,379 ADOBEF~1.LST AdobeFnt10.lst
08/03/2007 07:59 <DIR> Desktop
15/11/2006 11:11 <DIR> FAVORI~1 Favorites
08/02/2007 07:40 <DIR> INCOMP~1 Incomplete
08/02/2007 07:58 <DIR> MYDOCU~1 My Documents
24/10/2006 07:55 0 qemu-img.exe
07/02/2007 13:17 <DIR> Shared
20/07/2006 07:44 <DIR> STARTM~1 Start Menu
19/08/2005 01:08 0 STI_TR~1.LOG Sti_Trace.log
3 File(s) 121,379 bytes
11 Dir(s) 5,829,396,992 bytes free
you need to find the folder name and then look to the right for the foldername~1 then type del foldername~1
massivewangers
30
Oct 1, 2015 07:40 PM
jay030787
Sep 25, 2015 01:38 AM
Andypandy260
Sep 23, 2015 10:28 PM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
