Fuel pump questions (Stack Dash related)
Old Mar 5, 2007 | 09:03 PM
Rippers's Avatar
Rippers
Monte Geek
Default Fuel pump questions (Stack Dash related)
I've installed my Stack Dash with the fuel pressure sensor and can now get a reading 53.3 (assuming thats psi) ignition switch 2 (engine not running).
Can you tell by the pressure the spec of the fuel pump ie whether its standard or grp-a etc
What pressure should I set the alarm to? 50 ?
Old Mar 6, 2007 | 01:33 PM
Turby2's Avatar
Turby2
AFAIK The stack dash is basically reporting the pressure due to the effects of the fuel pressure regulator (FPR).
As for alarms, I used to set mine after driving it and monitoring the "normal" values. Most FPR are set to operate around 3.5 bar, so set alarm to 3 bar (approx 45 psi) should be fine.
HTH
Old Mar 6, 2007 | 04:55 PM
timrud's Avatar
timrud
Yeah set it just under the normal fuel pressure at idle.
Mine when its about to run out of fuel runs at about half fuel pressure. I've got about 5 seconds then
Old Mar 6, 2007 | 04:59 PM
GARETH T's Avatar
GARETH T
you cant set an alarm,,, as the pressure will go up and down according to the pressure in the inlet manifold
what you are seeing is what we call base pressure,,, this is the pressure in the rail at atomspheric pressure
if you run 20 psi it will show 73.3 psi (53.3+20)
if you are on over-run and the inlet pressure is now -10psi, your fuel pressure will be 43.3psi (53.3-10)
and no you cant tell what pump you got
Old Mar 6, 2007 | 07:58 PM
GARETH T's Avatar
GARETH T
bttt
Old Mar 6, 2007 | 09:58 PM
Rippers's Avatar
Rippers
Monte Geek
Good info guys cheers
Gareth you had any luck with the nudge nudge wink wink for the exhaust temps
Old Mar 7, 2007 | 08:39 AM
GARETH T's Avatar
GARETH T
im off work dude, but i havent forgotten (well just gotta remember when im in my parts bins )
Old Mar 7, 2007 | 09:18 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Mine alarm is set to 35psi - you shouldn't see any less than this even with a vacuum (de-accelerating).
Old Mar 7, 2007 | 09:26 AM
GARETH T's Avatar
GARETH T
dont you mean its impossible to see less than that if all systems are working?
Old Mar 7, 2007 | 09:34 AM
Mike Rainbird
Caraholic
Same difference .
Old Mar 7, 2007 | 09:58 AM
Rippers's Avatar
Rippers
Monte Geek
Old Mar 7, 2007 | 10:06 AM
GARETH T's Avatar
GARETH T
but a 35 psi alarm isnt going to stop your engine from blowing up
can you set algorithms for the alarms?
Old Mar 7, 2007 | 01:38 PM
Mike Rainbird
Caraholic
If you set it much higher than that, it will be forever going off (eg, every time you lift off the throttle and / or at idle ) .
You can do a pressure difference ratio with the Defi's, so if it ever sees less than this it warns you .
Old Mar 7, 2007 | 01:47 PM
GARETH T's Avatar
GARETH T
ah cool,,, i didnt know a defi could do that
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
