power boost valves!
Old Mar 5, 2007 | 04:19 PM
cpaul4's Avatar
cpaul4
Default power boost valves!
does anyone on here use them, and wat benefits do you get.
Old Mar 12, 2007 | 08:28 PM
bick888's Avatar
bick888
yea, i want to know aswell!!!
Old Mar 12, 2007 | 10:53 PM
focusphantom's Avatar
focusphantom
I don't know there must be a wealth of knowledge on this forum and yet whenever we ask questions nobody seems to want to answer, i have been asking the same question about FSE boost valves, Ecotek valves, induction kits, exhausts and other things and you get nowhere and the only reason i can think of is because they've been there done that and got the t-shirt and therefore can't be bothered to reply.....
Old Mar 13, 2007 | 01:19 AM
FRS 3409's Avatar
FRS 3409
basically a power boost valve is a way of turning up your fuel pressure.
in the right hands and on a well set up engine that has had the airflow increased to match it can be useful. if fitted and not mapped for the car though can have a detrimental effect and may make the engine produce less power.
benefits can be found on some cars though. i know of a few people that have done the usual 130 bhp upgrades to 1.8 escorts i.e cams, throttle body, mass airflow sensor etc and incorpated a power boost valve into the build before getting the car sent off for a remap. these have come back with a lovely power curve with no flat spots. very nice to drive in the road.
in a word yes they are useful if used correctly.
as for the ecotek valves they basically fit into a vacuum pipe going into the inlet manifold from brake servo. this creates an amount of turbulent air that is meant to have a positive effect on the way the air and fuel mixture is delivered. results vary on different cars. most people say they notice better fuel consumption, some say they erradicate flat spots through the rev range, some notice no changes. all down to personalpreference really. the best thing to do is try and borrow one and see if it makes a positive difference to your engine.
hope this helps a little
ian
Old Mar 13, 2007 | 09:25 AM
focusphantom
Ye ah thanks very much thats very informative
Old Mar 13, 2007 | 10:41 AM
watson's Avatar
watson
FRS 3409 said it all,
I would only get one if you are planning on a live mapping because if they dont get the right mixture then you will start getting problems left right and center.
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
cossirob
Sep 3, 2015 09:17 PM
