4x4 cossie owners ATTENTION!!
Old Feb 23, 2007 | 10:45 AM
kjc300's Avatar
kjc300
Default 4x4 cossie owners ATTENTION!!
Has anyone changed their alternator belt tensioner before? Do you have to change the whole thing or just the pulley wheel?
I think the bearing has gone in mine
Old Feb 23, 2007 | 11:06 AM
cozmeister's Avatar
cozmeister
More boost Igor!
No I haven't mate, and the Workshop manual doesn't say how to do it. Is it like a dull whining noise? My whining noise came from the cambelt tensioner...
Old Feb 23, 2007 | 11:10 AM
xr4x4rs's Avatar
xr4x4rs
the main thing is just spring loaded
to take the while lot out
i think its a 15mm bolt that sits somewhere behind the p/s bracket
good luck getting to it
for just the pulley then just undo the the bolt on the pulley wheel
but as you undo it adjusts tension so your pushing against the spring and can be a pain
but can be done
Old Feb 23, 2007 | 11:11 AM
kjc300's Avatar
kjc300
No, it's not whining more rattly - but it shuts up if I squirt wd40 on it so I'm sure its that (I think ). I can see it moving slightly, side to side when I rev the engine.
Old Feb 23, 2007 | 11:13 AM
kjc300's Avatar
kjc300
but can be done
probably guarantee you can't get just the pulley!!!
Old Feb 23, 2007 | 12:34 PM
IANS2RST's Avatar
IANS2RST
no u have to get the whole assembly, costs about £85 iirc
tha rattling is caused by the spring not holding tension
Old Feb 23, 2007 | 12:49 PM
kjc300's Avatar
kjc300
Knew it!!! Cheers
Old Feb 23, 2007 | 01:50 PM
Bullett's Avatar
Bullett
make sure you do it whole mat,mine went on the way to combe 2 years ago.overheated the car on the motorway but i got away with the rad going not headgasket
Old Feb 23, 2007 | 02:08 PM
GUZZLER's Avatar
GUZZLER
Kev, £82.62 + vat, finnis, 1663 019.
Old Feb 23, 2007 | 07:31 PM
Damo V's Avatar
Damo V
4x4 or ECos??
I replaced my ECos one a while back, JUST the tensioner and while in situ, was straightforward enough, knuckle scratch time though..
Old Feb 23, 2007 | 07:34 PM
LeviA's Avatar
LeviA
I get a whiney squeeky noise but just blast it with WD40
Old Feb 24, 2007 | 12:08 PM
kjc300's Avatar
kjc300
Cheers guys,
Got one today £97
Matt, where's your address???
Damo, Escos - got the alternator to do too so shouldn't be too hard!!
truffleshuffle
Sep 10, 2015 09:35 PM
Thanasis
Sep 7, 2015 07:33 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
