reverse gear ERST
Old Feb 21, 2007 | 08:23 PM
RST Ski's Avatar
RST Ski
Default reverse gear ERST
when i select reverse for the first time in the mornings in goes in fine, as soon as the cars driven abit down the road say 10mins later everytime i select reverse it crunches very loudly even if i go back into neutral first. is this clutch or gearbox fault?
Old Feb 22, 2007 | 12:28 AM
NUTS RuS's Avatar
NUTS RuS
Any oil in it ?
Reverse has no syncro ring so will make that noise its not stopped
Old Feb 22, 2007 | 01:43 PM
SafeChav's Avatar
SafeChav
Could also be a sign of the clutch starting to wear!
Is it difficult to get into 1st aswell? And does it creep forward at all when you leave it in gear with the clutch in?
Old Feb 22, 2007 | 03:39 PM
Alvyn's Avatar
Alvyn
try selecting 5th gear before selecting reverse and see if there's any difference! could also be the cables scretched!
Old Feb 22, 2007 | 05:33 PM
SafeChav's Avatar
SafeChav
The auto adjuster should take up the slack in the cable
Worth a thought though, the adjuster has gone on my run about and mines a bit of a slag until its warmed up (into any gear) its fine after though.
Old Feb 23, 2007 | 04:22 PM
RST Ski's Avatar
RST Ski
i really have to put my foot down to stop it creep? yeh selecting first and be a sod aswell
Old Feb 23, 2007 | 04:37 PM
SafeChav's Avatar
SafeChav
It could be as simple as your quadrant is fucked on the pedal.
But, i know on mine the clutch is completely ragged having covered 110k. You may well find the springs are snapping on the pressure plate. Is the pedal heavy and springy?
Old Feb 23, 2007 | 04:53 PM
RST Ski's Avatar
RST Ski
yes id say so
Old Feb 23, 2007 | 07:31 PM
SafeChav's Avatar
SafeChav
More than likely a new clutch set in the pipe line then
The pedal goes hard when the springs start snapping, as the load has to be spread across less springs, meaning more effort to disengage
tankybaby66
Feb 6, 2016 02:24 PM
Mc5506
Oct 5, 2015 09:57 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
