battrey pushing bonnet up
i have a heavy duty battrey on my 1.6 zetec escort as i go throught normal battreys easy lol
the problem is that the battrey pushes the bonnet up an inch or so and goes above the wing, and i don't want bonnet rasiers
if i don't have the battrey cover on it cates the terminals plus the try still fucking leaks after i filled the crack with silicon
does anyone know have to not make it stick up,
(and i'm not putting the standerd battrey in as its shit
Fit the right size battery!!
Size doesn't matter. You can get batteries with much more power than standard in the same case size.
Where did you get it? Did they tell you it would fit?
If they did, then get them to exchange it.
If the bonnet touches the +, you could soon discover that your escort is now a burnt out shell!
Should be an 065 or an 075 I would think.
If a battery isn't charged regularly either by driving the car or by trickle charging the plates inside start to corrode and the battery stops working and won't charge. If it gets to that point it's fooked and will need replacing.
Adam Graham
Sep 6, 2015 06:04 AM
