Lazy Tappet
Old Feb 20, 2007 | 06:12 PM
RST Ski's Avatar
RST Ski
Default Lazy Tappet
think i may have a lazy tappet, knocks sometimes, can this be cured or does it need replacing?
Old Feb 20, 2007 | 06:33 PM
ivorbiggun's Avatar
ivorbiggun
I've got an indolent idle valve....................
Old Feb 20, 2007 | 06:34 PM
ivorbiggun's Avatar
ivorbiggun
or is that 'idle' idle valve......
Old Feb 20, 2007 | 06:38 PM
Try some WYNNS oil system modifier.
Despite odd name it is for this kind of thing and works wonders, I have used it in my cos myself to cure this.
Old Feb 20, 2007 | 07:36 PM
SafeChav's Avatar
SafeChav
KNOCKING......
Tappets?
Old Feb 21, 2007 | 06:43 AM
Tappets can knock if bad enough, as clearance between cam and follower/valve head bang together but must be really bad.
Old Feb 21, 2007 | 07:25 PM
SafeChav's Avatar
SafeChav
How can a cam follower of such small size make a "knocking" noise similar to that of a worn bottom end.
Old Feb 21, 2007 | 08:44 PM
slimwynn's Avatar
slimwynn
tappets tap
Old Feb 21, 2007 | 10:23 PM
RST Ski's Avatar
RST Ski
is this a flush or a additive?
Old Feb 21, 2007 | 10:28 PM
RST Ski's Avatar
RST Ski
i had a tappet not moving at all once, after i changed stem seals, the valve spring tool compressed the lifter and it didnt return itself, when i started it up that one tappet KNOCKED very loudly, i removed the rocker cover n removed that lifter and kept crushing the lifter back n fourth in a vice untill it free'd up again, put it back to together n it was silent again.
Old Feb 22, 2007 | 01:08 PM
SafeChav's Avatar
SafeChav
I know what you mean exactly, but i wouldnt say that was a knocking noise!
If your having problems with the top end i would inpect the oil ways on the head, and remove the lifters and soak them in some petrol or thinners, you'll find the oil inside seeps after not very long
Old Feb 22, 2007 | 05:57 PM
RST Ski's Avatar
RST Ski
il give that a go
Old Feb 22, 2007 | 06:02 PM
Sorry safechav could not find the author saying "like a bottom end"
Sound is produced by impact, remember all peoples descriptions of the same thing will differ slightly.
Old Feb 23, 2007 | 05:55 PM
RST Ski's Avatar
RST Ski
after ive soaked them in petrol, il put them back in, shall i tip fresh oil onto them or will that not make a difference?
Old Feb 23, 2007 | 07:29 PM
SafeChav's Avatar
SafeChav
Stand them on some cloth somewhere warm for a day or so, and you'll probably find some more oil seeps out, and then yea, fresh oil will never go a miss
While they are out inspect the faces for pitting and dishing etc. Ideally if they are in good condition they will be completely flat. And also if they don't want to pull out of the head easy leave them be and get back to me!
Old Feb 24, 2007 | 01:20 PM
RST Ski's Avatar
RST Ski
is white spirt a thinner? could i soak them in that?
Old Feb 24, 2007 | 01:35 PM
SafeChav's Avatar
SafeChav
Not too sure on that mate! Can't really be any harm in trying it though.
Have you not got a bit of petrol in a jerry can?
Old Feb 24, 2007 | 01:46 PM
RST Ski's Avatar
RST Ski
ive removed the rocker cover to find this one lifter sitting higher up than the others! this isnt right is it?
here it is again
all the others sit like this?
think this could be my problem, thenoise does sound around where this lifter is aswell
Old Feb 24, 2007 | 01:56 PM
SafeChav's Avatar
SafeChav
Yea! Because the cam lobe is pushing it up, and the valve spring is greater than the pressure of the spring within the lifter, As soon as u start the engine the oil pressure will return it to normal.
Old Feb 24, 2007 | 01:58 PM
RST Ski's Avatar
RST Ski
r ok, just thought it was abit wierd that this one lifter was the only one raised, il give them all a saoking anyway, see wot happens
Old Feb 24, 2007 | 02:17 PM
RST Ski's Avatar
RST Ski
lifters dont seem to be worn or marked or dished and also checked the oil ways in the holes for the lifters,
does it matter wot order they go bk in? ive kept them in order but thougt id ask anyway
there soaking now
Old Feb 24, 2007 | 02:21 PM
SafeChav's Avatar
SafeChav
Did they all pull out smoothly? Not tightness to any of them?
Good man for keeping them in order
Old Feb 24, 2007 | 02:22 PM
RST Ski's Avatar
RST Ski
yeh came straight out with a magnet
Old Feb 24, 2007 | 02:23 PM
SafeChav's Avatar
SafeChav
Unlikely there is any significant wear on the cam or lifters then.
If the lifters were dished or worn it would be obvious, when they are ok they look very flat and highly polished in appeareance
Old Feb 24, 2007 | 02:26 PM
RST Ski's Avatar
RST Ski
il leave them soaking for abit then and put them bk in, fingers crossed
Old Feb 24, 2007 | 02:28 PM
SafeChav's Avatar
SafeChav
As i said its best to stand them on a cloth after somewhere warm for a few hours, you will find more seeps out and you wont want to mix whatever you've soeaked them in with your engine oil
Old Feb 24, 2007 | 02:37 PM
RST Ski's Avatar
RST Ski
will do
Old Feb 26, 2007 | 03:55 PM
RST Ski's Avatar
RST Ski
put it back together, noise is still there and guess what, its the water pump! can hear it clearly now
Old Feb 26, 2007 | 04:19 PM
SafeChav's Avatar
SafeChav
You div
I wouldnt recommend driving that in any way until you change it, if the pump ceases - good bye cam belt and top end
Old Feb 26, 2007 | 05:41 PM
RST Ski's Avatar
RST Ski
You div
tell me about it
foreigneRS
Technical essay Archives
Jul 20, 2025 05:28 PM
davidfordrs
Sep 21, 2015 04:23 AM
Roosie
Aug 13, 2015 07:40 PM
Jim Galbally
32
Aug 13, 2004 09:12 AM
foreigneRS
Jul 20, 2004 11:06 AM
