escort RST. gauge fitting......
Old Feb 13, 2007 | 08:39 AM
b_kennedy's Avatar
b_kennedy
Default escort RST. gauge fitting......
Hi guys. Could any one tell me how to wire an - oil pressure gauge and a
- water temperature gauge
on an escort rs turbo please. Apart from the obvious of the wiring them to lights etc. Where do i wire it to and where can it be found on the engine. Many thanks
Old Feb 14, 2007 | 03:10 PM
Oil pressure use a "T" piece in the original pressure switch location to run pressure switch and new OIL PRESSURE SENDER.
For water temp guage, you will not be able to use the original in case it is calibrated differently(most liklely) to ford one so will need to find a way of inserting somewhere, maybe make/buy a metal section to go in a hose with a boss in it for temp sender.
Old Feb 14, 2007 | 05:41 PM
b_kennedy's Avatar
b_kennedy
thanks for the help. I'll check it out tmorrow. thanks again
Old Feb 14, 2007 | 06:37 PM
SafeChav's Avatar
SafeChav
Strip all the wires back, twist them all together and close your eyes while you turn the key
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
