Running in a new engine, need guidance
Old Feb 10, 2007 | 06:55 PM
GraphiteGray's Avatar
GraphiteGray
Default Running in a new engine, need guidance
Hi all
As title im getting near to the stage where i'll be firing up my engine for the first time. The engine has been rebuilt with new pistons/rings etc etc so i need to do it right
I know the cam has to be run in (2500rpm for 20 minutes) but im wondering about things like:
Setting the timing on the dizzy
What oil to use
Running in the engine generally (how many miles, how fast etc)
Can i get a tuning company to run her in?
Any tips?
Any help greatly appreciated
Thanks for looking
Old Feb 11, 2007 | 12:00 PM
fast_ford_uk's Avatar
fast_ford_uk
use running-in oil for the first 500-1000 miles then do a oil and filter change with sum decent oil, dont take the engine over 3500rpm for the first 500 miles.
as for timing the dizzy do it once started as best as you can, then recheck after a couple of hundred miles as it will take a while for the rings to bed in etc
dont nurse the engine thou, go up through the gears as normal just keep the revs low
Old Feb 11, 2007 | 12:11 PM
addiction's Avatar
addiction
use cheap mineral oil to run in for 500 miles then change to fully synthetic!
dont go above 3500 rpm and stay off the boost. dont do the 500 miles on the motorway! keep goin up and down the revs to prevent bore glazing
Old Feb 11, 2007 | 12:22 PM
fast_ford_uk
Old Feb 11, 2007 | 06:54 PM
GraphiteGray
Great info there guys cheers for that
So its a bit of A and B road driving then, ive been told not to leave the car idling for too long while running in, is that true?
Old Feb 11, 2007 | 06:58 PM
Fiecos Dan's Avatar
Fiecos Dan
Have a read, some where in there your read my thoughts, and advice.
https://passionford.com/forum/viewto...632&highlight=
Old Feb 11, 2007 | 07:15 PM
GraphiteGray
Sorry mate i cant read the link, gold members only
Old Feb 11, 2007 | 11:24 PM
SafeChav's Avatar
SafeChav
While we are on the subject.....this whole "running the cam in for 20 mins @ 2500rpm" business........
Why? Whats it meant to do?? Just something thats been bugging me for a while now
Old Feb 12, 2007 | 05:46 PM
Chris69's Avatar
Chris69
u just do its one of these unanswered questions like wot came first the chicken or the egg
and besides it says it on the box
Old Feb 12, 2007 | 05:58 PM
SafeChav's Avatar
SafeChav
Thanks for that
Fuckin chocolate teapots spring to mind
Can anyone tell me WHY
Old Feb 12, 2007 | 06:50 PM
Fiecos Dan's Avatar
Fiecos Dan
As the cam/followers need 20min's of good, clean, high pressure/flow of oil to reduce chance of wear.
It needs to be @ 2500 rpm for the oil flow/pressure
and for 20mins, as it needs to beheld with the oil flow/pressure to after oil got to working temp.
Also i think some of its to cover the cam producers back.
i usually do it @ 2500 rpm till oil temp has pasted normal running temps and all adnormal noises have dissappeared.
Old Feb 13, 2007 | 11:47 AM
xrmalin's Avatar
xrmalin
Fiecos Dan
Is this the same for all cvh cams wether its turbo'd or not ?
Old Feb 13, 2007 | 03:03 PM
SafeChav's Avatar
SafeChav
You see though..........CVH top ends are poor enough designed as it is, have you ever taken the cap off immediately after starting it from cold and seen how much oil there ISN'T flowing across the top end .....?!
Additional to the fact they have very excessive spring pressures, i would of thought raising the RPM that high would ruin it more than anything, especially when the oil is cold and thick............
Old Feb 13, 2007 | 03:11 PM
JamboRS's Avatar
JamboRS
focus rs 1672
the cam comes with a lube to protect it for this reason
Old Feb 13, 2007 | 03:16 PM
SafeChav's Avatar
SafeChav
Indeed, but how long do you think that stays on the lobes for once the lifters have graunched past the lobes a couple of times...........
Old Feb 13, 2007 | 07:20 PM
Fiecos Dan's Avatar
Fiecos Dan
Originally Posted by xrmalin
Fiecos Dan
yes mate,
same on most engine that i know of.
Safechav.
i believe its the very reason of lack of oil on start up and as oil is cold, is why it needs to be held at those revs,
and as mentioned the cam lube should protect it till oil is present.
Old Feb 13, 2007 | 08:08 PM
SafeChav's Avatar
SafeChav
Hmmmmm, im very dubious about it and ive never actually fitted a brand spanker cam myself. And when i do shortly.....i will never be suffering from wear again
They are, but EFI cams are re-profiled and produce a little bit more power than the earlier MFI cams. All are cross-compatible though
Old Feb 13, 2007 | 08:34 PM
Fiecos Dan's Avatar
Fiecos Dan
Heres a cut and paste of what i put on the other thread.
I've tried quite a few different ways of running in,
and found running-in is best by
Always warm up gently, not idleing. and fueling to be 14.2-15.0:1,
whilst at different times, checking everything.
30 minutes between 2500-3000 rpm,
0-50 miles, easy upto 3000rpm, changing the loads. no more than 25% throttle, Change oil.
50-200 miles, as above but to 3500rpm
200-300miles, 50% throttle, 4000 rpm, no boost.
300-400miles, as above but with boost
400-500miles, 50% throttle, 5000 rpm.
oil change,
500-1000miles, full throttle, low boost setting (20psi on my cossie), full RPM.
1000 + Full boost (35psi on my cossie).
Job done
The above way, has given me best results on CVH's and YB's, going by compressions, leak down test's, and longtivity of the whole engine.
i've tried 1000,500 etc ect of ploding around (like most places say) and rings never bed in correctly.
big_Rad
Sep 15, 2017 09:36 AM
Red_bull
Aug 25, 2015 06:27 PM
Zoggon
Aug 10, 2015 10:39 AM
knight19770
Aug 4, 2015 12:36 PM
lockie
Jul 31, 2015 10:03 PM
