non starting
Old Feb 5, 2007 | 12:23 PM
marshy3563rst's Avatar
marshy3563rst
Default non starting
hi can anyone help i got a s2 which wont start all the ignition system is good all the fuel is good but it wont start, if i take out an injector and put it bk in it will start but after i turn the car of i can start it again untill i take out an injecter does anyone know why? thanx paul
Old Feb 5, 2007 | 01:20 PM
Dragsteer's Avatar
Dragsteer
maybe injecotr leak?
Old Feb 5, 2007 | 02:33 PM
Marc LJX's Avatar
Marc LJX
Maybe its the fuel pump relay sticking?
And in the time your spending removing the injectors the relay is cooling down enough to work again, if you know what i mean.
When it wont start after running, let it stand for a while without touching anything, then see if it starts after 20 minutes or so.
Old Feb 5, 2007 | 03:21 PM
Dragsteer's Avatar
Dragsteer
how cen I check if fuel pump relay sticking?
Old Feb 5, 2007 | 03:27 PM
Marc LJX's Avatar
Marc LJX
I cant remember if they have an internal wiring diagram on them showing the contacts?
When the car wont start, you could remove the relay and check that the contacts are open/closed as per the diagram with a continuity meter...
Or just replace it, thats the easiest way!
Old Feb 5, 2007 | 04:30 PM
marshy3563rst
even when i leave the the car the same thing happens even the garge dont understand why it does it.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
