i know that this is the pin that the signal wire goes to from teh ecu,, but when i tested it with my voltmeter there was about 4.6 volt output from pin 20 with the ignition on,
is this correct. only reason im asking is due to the fact that i thought it was suppose to be an input wire and not give an output voltage.
