Advantage/Disadvantage removal of dump valve
Old Feb 3, 2007 | 02:58 AM
captiva's Avatar
captiva
Default Advantage/Disadvantage removal of dump valve
I have been reading threads on running without a dump valve and cannot establish if it is good or bad. I am running a Saff 4x4, 803's,3 bar map, NMS stage 3 chip,K&N panel filter. For maximum performance, as I am not interested in making noises, should I remove the Dump valve and why if Ford put it there in the first place?Can anyone help please
Old Feb 3, 2007 | 06:47 AM
wimwerf's Avatar
wimwerf
some say only with if t4 or bigger on high boost...
Old Feb 3, 2007 | 08:22 AM
Ask yourself this question, WHY DOES A MANUFACTURER FIT A PART IF NOT NEEDED.
The answer is to AVOID WARRANTY CLAIMS for knackered turbo.
Hiow much damage it will do has never been established but as air itself is damaging at high speed think of your poor turbo's comp wheel being subjected to such forces, did you know the tips exceed 500mph ?
Old Feb 3, 2007 | 07:01 PM
snow*'s Avatar
snow*
I absolutely hate the dump valve sound also.
I'm still searching for a way to have silent gear changes
Old Feb 4, 2007 | 07:16 AM
For anyone that wants SILENT GEAR CHANGES just dump excessa ir into filter housing, AS FORD DID.
I am going to be using a LPG valve to switch mine between noisy/quiet.
Old Feb 4, 2007 | 10:21 AM
M.A.D.RST's Avatar
M.A.D.RST
Why not just buy a recirculating dump valve
Old Feb 4, 2007 | 06:16 PM
RECIRCULATING DUMP VALVE- AS FORD FITTED.
Old Feb 5, 2007 | 09:19 AM
snow*'s Avatar
snow*
I have a recirculating Bailey DV-30 dump valve. As I fitted a Pace RS500 spec intercooler I had to lose the intake pipe that used to feed the airbox as the intercooler won't fit otherwise.
Now I have a Group A filter and Trumpet with the recirculating dump valve plumbed into that. The air still escapes through the filter on gear changes giving me that annoying, attention seeking sound
Old Feb 5, 2007 | 09:56 PM
Sideways_Sierra's Avatar
Sideways_Sierra
Wassa matter with a bitta chatter ??
Old Feb 6, 2007 | 04:28 AM
snow*'s Avatar
snow*
It's fine if you're an attention seeker.
I prefer to not drive around with my stereo pumping and huge whooshing sounds every time I change gear and hoping that everyone will notice me. I'm more of the low key driver.
Old Feb 6, 2007 | 04:52 AM
captiva's Avatar
captiva
We seem to be getting away from my original question which is, for maximum performance (which is all I am interested in) should I leave the dump valve on? I guess the chatter when I take my foot off the "loud" pedal is the turbo slowing down real quick as there is a pressure build up in the intercooler and cannot pump any more. As I understand it the dump valve releases that built up pressure back in to the turbo on the intake side to spin the turbo up again. This I would see as helping the situation not hindering it. Am I right?
Old Feb 6, 2007 | 10:13 AM
fatmike's Avatar
fatmike
what hapens is when u are boosting u get all ya boost pressure go in to the engine then when u shut the throtle off the the throtle butterfly is like a brick wall for the air causing it to stop dead and the chatter is the turbo choping the returning air up realy quickly.By fitting a dv u alow the air to vent away alowing the turbo to ceep spining freely alowing a faster spool up. a recurculating dv just dumps the air back in to the system has the same affect but should b vertualy silent hope that healps
Fudgey
Sep 17, 2015 01:06 PM
Si B
Sep 12, 2015 06:49 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
