engine warning light on FOCUS
Old Feb 2, 2007 | 08:12 PM
efiste2's Avatar
efiste2
Default engine warning light on FOCUS
does anyone know how to reset these things, a mate had a coil pack go on his 1.6 focus, now its fixed and runs fine but the engine warning light is still on.................any tips or is it a FORD job
Old Feb 2, 2007 | 09:04 PM
lukes1's Avatar
lukes1
not at all, the coil problem has registered a fault in the ecu, so hopefully its just a case of having the trouble codes erased.most decent back street garage should have a code reader, and could put the light out.
Old Feb 3, 2007 | 07:16 AM
FIRST pull the K.A.M. fuse for a minute or so see what happens.
Secondly I would be very surpirsed if a duff coil pack would flag a warning as the system has no way of knowing if the thing is working or not, ie wether sparks delivered it only knows that the electric was delvered to coil nothing else.
What is more likely particularly if twin HEGO is that it has flasshed a sensor malfunctuion due to unburnt fuel in exhaust and differential HEGO readings.
Old Feb 3, 2007 | 07:44 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
If any of his mates have a Bluefin Superchip handset - these can be uses to read and remove fault codes
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
