Piston movement
Old Jan 31, 2007 | 03:14 PM
khanny's Avatar
khanny
Default Piston movement
Right the heads off and did the compresion test before
cylinder1 100psi
2 50
3 150
4 150
but at the top of the piston stroke 2 and 3 have a fair bit of movement but 1 and 4 dont now i thought it would be 1 and 2 with the readings any ideas any 1
Old Jan 31, 2007 | 05:57 PM
nick series1's Avatar
nick series1
When you say movement what do you mean - Up and Down ??
Is it not travelling to the top of the bore ??
Old Jan 31, 2007 | 07:14 PM
SafeChav's Avatar
SafeChav
Have you identified whats made the compression low yet?
Could be valves, gasket, rings/worn/damaged bores, cracked block/head (unlucky if its that )
Old Jan 31, 2007 | 07:58 PM
khanny's Avatar
khanny
they go to the top of the bore and move side to side thats in two and three not in one and two like i thought it would be with the compression test i would put some pics on but it keeps saying they are too big and i dont know how to shrink them if anyone wants to send me their email address i will send them a video to show them what it is doin.
bottom of head looks ok inside at top looks like its had some welding done
Old Jan 31, 2007 | 08:00 PM
SafeChav's Avatar
SafeChav
You got msn? Add me to it if you have!
i can host the pictures for you if you like or shrink them
Old Jan 31, 2007 | 09:23 PM
khanny's Avatar
khanny
i aint got msn but i will sort it out tomorrow
Old Jan 31, 2007 | 09:37 PM
SafeChav's Avatar
SafeChav
(Get MSN )
Old Jan 31, 2007 | 11:25 PM
ram's Avatar
ram
Has a large member
Originally Posted by SafeChav
(Get MSN )
lol
Old Jan 31, 2007 | 11:42 PM
SafeChav's Avatar
SafeChav
(Get MSN )
lol
Its free after all (duno what i'd do without it )
Old Feb 1, 2007 | 12:00 AM
khanny's Avatar
khanny
Whats the best thing to clean the crude and bits of gasket of the head and how do i know if it needs skimming
Old Feb 1, 2007 | 12:07 AM
rst_cabby's Avatar
rst_cabby
To clean the head up use a fine emery cloth (it's like sandpaper but it's used for metalwork) & some wd40 ......
If you have solid lumps of gasket on the face then gently use a stanley blade or scrapper BUT it must done carefully as not to pit any of the face.
Old Feb 1, 2007 | 12:11 AM
khanny's Avatar
khanny
nice 1 cheers
Old Feb 1, 2007 | 12:58 PM
SafeChav's Avatar
SafeChav
Khanny mate, i'd get it down to your local engineering place they will usually tell you if it needs a skim or not for free, its always best to have a very light skim doen to make sure it seals up well.
Old Feb 1, 2007 | 02:12 PM
khanny's Avatar
khanny
Ye will do what actually is a skim do trhey take the alloy of or put alloy on?
Old Feb 1, 2007 | 02:21 PM
antony215's Avatar
antony215
Escort Rs Turbo
They just take off/skim a VERY,VERY small amount off the bottom of the head
Old Feb 1, 2007 | 02:25 PM
khanny's Avatar
khanny
Ah right cheers they must use really presice tools then do i have to clean it all up first and remove all the valves and things
Old Feb 1, 2007 | 02:34 PM
antony215's Avatar
antony215
Escort Rs Turbo
It would probably make there life easyer if you did give it a clean off if it's that dirty but you dont need to take the valves out or any thing
Old Feb 1, 2007 | 03:01 PM
SafeChav's Avatar
SafeChav
They machine it on a latha Khanny
theres a few different ways of doing it, fly cutting apparently gives the best finish but if the head is very corroded it can take small chunks out apparently.
Clean if off as suggested, i usually find its stuck to the block though (everyone elses always seem to come off with no mess )
Old Feb 1, 2007 | 04:30 PM
khanny's Avatar
khanny
It came of easy was really lose the head bolts werent all that tight either
Old Feb 1, 2007 | 04:43 PM
SafeChav's Avatar
SafeChav
How tight are we talking?
Did you undo them with a ratchet?
Old Feb 1, 2007 | 06:28 PM
khanny's Avatar
khanny
Ye but they wernt that tight i thought they would have been a lot tighter
Old Feb 1, 2007 | 06:35 PM
SafeChav's Avatar
SafeChav
They should of been fairly tight with a ratchet.......
Still we'll make sure they get torqued right this time round
Old Feb 1, 2007 | 08:39 PM
khanny's Avatar
khanny
Ye heres hoping
Old Feb 2, 2007 | 12:25 AM
SafeChav's Avatar
SafeChav
Ye of little faith
Old Feb 2, 2007 | 06:31 PM
khanny's Avatar
khanny
Took the h3ead today and didnt even need skimming the guy said defo not the headgasket so fezzy bottom putting on tommoro fingers crossed all
Old Feb 2, 2007 | 06:39 PM
SafeChav's Avatar
SafeChav
Are you converting to EFI while your there?
Old Feb 2, 2007 | 06:45 PM
antony215's Avatar
antony215
Escort Rs Turbo
I doubt that very much
Old Feb 2, 2007 | 08:20 PM
khanny's Avatar
khanny
M8 the only thing i want this to do now is start, run, and boost
Old Feb 2, 2007 | 08:23 PM
SafeChav's Avatar
SafeChav
Fair enough.......does this bottom end have the EFI flywheel and crank position sensor fitted?
Old Feb 2, 2007 | 08:28 PM
khanny's Avatar
khanny
Was told to take the flywheel of mine on to the fezzy bottom all it came with is alternator and oil feed, i know i goty to change the oil feed and the inlet oil feed but anything else i should be looking at cheers
Old Feb 2, 2007 | 08:29 PM
SafeChav's Avatar
SafeChav
Ah right, yours will be fine. Just would of been nice if you had the EFI flywheel on there, because it would make your life VERY easy if you decided you wanted to go EFI soon
Old Feb 2, 2007 | 08:33 PM
khanny's Avatar
khanny
ye i do hyave the fezzy flywheel
Old Feb 2, 2007 | 08:46 PM
khanny's Avatar
khanny
dont i need loads of other stuff to convert to efi tho like inlet mani ect
Old Feb 2, 2007 | 09:36 PM
SafeChav's Avatar
SafeChav
Right then.........make sure you fit that fez flywheel (check if its got timing marks in the back)
And is the aluminium crank sensor holder bolted onto the block. Just fit them for now, if you decide to go EFI that is the hardest part of it so you will be WELL ahead of the game
Old Feb 2, 2007 | 09:49 PM
khanny's Avatar
khanny
Was told to swap it for the escort 1 something to do with timing or crank sensor or something like that cant quite remember....and what am i looking 4 for the aluminium crank sensor,
also if i do keep the fezzy 1 on do i need to do anything else or just bolt straight to the gear box, and is there anyway to tell if the bottom end is shagged the pistons all move freely tutrning the flywheel and at the tdc of every piston theres no rocking they even look quite new the piston tops
Old Feb 2, 2007 | 09:51 PM
SafeChav's Avatar
SafeChav
Hmmmmm not sure why they would of told u that?
Have you got a digital camera?
Old Feb 2, 2007 | 09:54 PM
khanny's Avatar
khanny
ye m8 also the guy at the auto engineers sayed the welding in the head was from some1 opening up oil ways so the oil droped straight to the sump kweeping it out of the head, what you not sure about
Old Feb 2, 2007 | 09:56 PM
SafeChav's Avatar
SafeChav
What welding is that mate?
Well i was going to get you take a couple of pictures for me. If you've got a FRST flywheel you would be INSANE not to fit
Old Feb 2, 2007 | 09:58 PM
khanny's Avatar
khanny
i will do you7 some pics m8 send me your email addy in a pm n il send you them says there to big when i try put them on here
Old Feb 2, 2007 | 10:00 PM
SafeChav's Avatar
SafeChav
my email address is on the msn button mate
Just out of interest why dont you download MSN?
