5th injector, extra fuel...
Hi
Anyone using the coldstart valve as an extra injector? Is it the best alternative for extra fuel or should I try to use some sort of efi injector?
Need to know this cos my engine doesnt get enough fuel when I'm running about 20psi boost pressure.
(hope anyone understands my swenglish
cheers
cheers
You asked if it is the best way, the answer is 'No'.
In my opinion, you need a proper injector, like a Bosch 803 mounted properly in the cross-over pipe, controlled by something like an ERL device.
I used a Lamndagauge to find out that there wasnt enugh fuel on the higher register.
So the coldstart valve is out of question then?
Has anyone here constructed their own 5th-inj system? Anyone using extra injector at all....
cheers
cheers
pm Graceland he made a fifth injector setup for one of his many creations, my mate also used it on his 2.0 litre xr4i turbo conversion, so it does work, im sure he will help you out
we use what is called a microfueler down here with a hop switch and an efi injector
at a set boost , the adjustable hop pressure switch closes and triggers the microfueler which is pulse adjustable , so you can vary the fuel. the injector is teed into the fuel rail
contact Gotech SA , they should be able to help you
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
