L8 lamba help
Old Jan 21, 2007 | 08:09 PM
stu21t's Avatar
stu21t
Default L8 lamba help
im need a lamba for l8 management.
i was going to get a universal lamba as i dont need the wiring plug as i need new wiring from the loom as some tit cut it off.
any1 know what range the lamba reads?
and how many wires or what colour they are?
ta.
Old Jan 21, 2007 | 08:13 PM
ECU Monitor Enthusiast
Any 3 wire lambda sensor will do the job ok.
They are the narrow band type.
I.E. they ONLY read accurate around the stoichmetric correct value.
This is the point of complete fuel combustion.
The sensors only work for idle and LIGHT loads only.
During high boost conditions (usually 5psi above) the sensor is not
used to tune the end and the ecu will revert back to the predefined map.
Hope that helps.
Old Jan 21, 2007 | 08:14 PM
Jay,'s Avatar
Jay,
Sponsor
stu ull need the a proper cossie on also you need to check if the chip is capable to still run it if its not a standard chip
Old Jan 21, 2007 | 08:18 PM
col cos1's Avatar
col cos1
i got a bosch one from stu at msd
Old Jan 21, 2007 | 08:19 PM
JjCoDeX75's Avatar
JjCoDeX75
I have just converted my 2WD to L8 with closed loop, and I used the aftermarket narrowband 3 wire sensor, which works fine.
As stated, it is only used for off boost stuff, and helps lots.
Speak to Stu at MSD, who I think will sell you either the genuine one, or the 3 wire one as you need!
JJ
Old Jan 21, 2007 | 08:22 PM
stu21t's Avatar
stu21t
for £30 i will fit 1 anyway, and i have a AFR gauge to so might as well get 1.
wont wire it up till it goes for mapping anyway as the chip is from a non lamba car.
cheers
jay, y do i need the cos one over a universal one? they all do the same, i thought the difference in car specific lambas was the lenght of wires and the plugs on the end of the cables??
Old Jan 21, 2007 | 08:26 PM
JjCoDeX75's Avatar
JjCoDeX75
cheers
Narrow band AFRs are a complete waste of time on tuned turbo cars imho.
Wideband if you want to know what is actually happening
JJ
Old Jan 21, 2007 | 08:31 PM
stu21t's Avatar
stu21t
but i cant use a wideband with the ecu, can i?
might have to get a wideband one as well.
Old Jan 21, 2007 | 08:36 PM
JjCoDeX75's Avatar
JjCoDeX75
Depends. Mine has a wideband lamnda sensor which goes to a controller box (tech edge). Mine is capable of producing a simulated narrow band output. This gives a voltage output that matches the ECUs expectations.
So the short answer is probably!
Most use one for the ECU and a separate boss welded into the zorst for the gauge!
If you are in the SW I am happy to show you mine - so as to speak!
JJ
Old Jan 21, 2007 | 08:44 PM
stu21t's Avatar
stu21t
show me yours i'll show u mine, lol
im not local m8 but thanks for the offer.
think i will get the 2 lambas, eventually
Old Jan 21, 2007 | 08:50 PM
JjCoDeX75's Avatar
JjCoDeX75
This is what I did!
I use the boss closest to the turbo for the ECU (given that it is more important!)
I have another boss a little lower that I use for the Wideband. I intend to try using the wideband controller for a simulated narrowband output as an experiment, though this will be only for the sake of my curiousity.
I bought the Track Tech setup, which I am very pleased with. Others use different.
Either way, visit their website, it tells you an unbelievable amount about the technology and the sensors etc. Start below...
http://<a href="http://wbo2.com/3b1/...efault.htm</a>
Enjoy!
JJ
Old Jan 21, 2007 | 08:55 PM
stu21t's Avatar
stu21t
cheers m8
Old Jan 21, 2007 | 09:07 PM
foreigneRS's Avatar
foreigneRS
Testing the future
don't fit one and then not wire it up - not good for it
Old Jan 21, 2007 | 09:08 PM
JjCoDeX75's Avatar
JjCoDeX75
Agree with this - unless you wire up the heater, in which case, it makes no odds unless I am mistaken?
JJ
Old Jan 21, 2007 | 09:23 PM
stu21t's Avatar
stu21t
ok will wire up the heater 1st. it wont be for long before setting up.
Old Jan 21, 2007 | 10:52 PM
Stu @ M Developments's Avatar
PassionFords Creator
Beware of cheap ones.
I tested a LOT of them on Cosworths before finally opting for teh ones i now supply. Its a hostile environment.
Old Jan 22, 2007 | 07:35 PM
stu21t's Avatar
stu21t
pm sent stu.
i was going to get these ones,
sounds ok?
http://www.lambdasensor.com/main/muniversal.htm
(£43 for a universal bosch 3 wire one)
and
http://www.lambdasensor.com/main/mwide.htm
£70 for a bosch wideband
ASHCOSSIE
13
Oct 26, 2009 08:15 PM
m_nettleship
May 22, 2008 06:41 AM
garyrs
Sep 22, 2007 06:23 AM
Paul J
17
Sep 1, 2006 03:51 PM
