EFI problem
I have no problem starting up a cold engine and everything is fine. But when the engine warms up sth happens - when pushing gas engine dies and seems like no power is transferred. What may be the problem: CPS? idle engine? Coolant Temperature Sensor? 3-bar MapSensor?
haaaa, u say u have a 3 bar map sensor!! has the ecu been mapped to run this?
so when u say 3 bar map sensor, u have a OFAB setup! has the ecu been mapped to run a 3 bar? cos standard should run a 2bar ithink, or maybe its a 2.5, but deffo not 3 bar...
i had problem with mine when i first converted, it would start, but wouldnt rev properly! it was the ECU that was faulty..
has it got a Map Supressor in the loom?
no supressor
not been mapped for the 3 bar
people say that you can run it without the supressor but if u ask me its not there for no reason,
it could be either of those 2 mate,
dont think it will be you ISCV..
ithink you may be better talking to safechav about this mate..
has it been setup since u converted? as when i first converted to EFI it ran mega rich
the co2 level where at 10.5% and really they need to be around the 2.5 areaish
It's worth noting, that these supressors are no longer available from Ford, and when they were available, they were Ł100 odd!
However, if you need one, speak to Kenny at http://www.motorsport-developments.co.uk/ He will be able to supply you one new for Ł50, delivered.
This is taken from http://www.rsbible.co.uk/
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
whey will make mapped for 3 bar map
