ice question time
Old Jan 20, 2007 | 10:58 AM
Default ice question time
what's the size of an 03 clio's head unit ?
is it the same as a normal aftermarket replacment unit ?
hope u's can help
rob
Old Jan 20, 2007 | 11:03 AM
Nath's Avatar
Nath
From memory its the same size but I'm 100% sure you'll need a wiring adapter
Old Jan 20, 2007 | 11:41 AM
i thought it would need an adapter
as i had to get one last time i used the head unit ive got
just a case of getting aroud to swapping them over now
Old Jan 20, 2007 | 01:36 PM
phil4x4saph's Avatar
phil4x4saph
I'm 100% sure you WONT need a wiring adaptor!
Old Jan 20, 2007 | 02:30 PM
wont!
Old Jan 20, 2007 | 02:35 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
No adaptors needed, straight forward swap
Old Jan 20, 2007 | 03:31 PM
a straight swap even with a sony cdx-S2200 ?
Old Jan 20, 2007 | 04:02 PM
phil4x4saph
Clio uses a standard ISO connector.
The Sony would have come with a short loom with a Sony connector at one end and a male ISO connector on the other. You will need this.
You wont need any other wiring adaptor. You will need a little plug for the aerial lead - which again the Sony would have come with from new.
If I'm wrong, I'll post a picture of my arse!
Old Jan 20, 2007 | 04:08 PM
i'l let you know if the pic's need'd when i find the key thingy's to get the old head unit out
DAN@ADRIAN FLUX
Insurance
15
Jun 30, 2018 09:00 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
borboyous
Aug 22, 2015 11:17 AM
saph in dorset
Aug 14, 2015 10:10 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
