Speedo needle loves a wobble
Old Jan 19, 2007 | 08:17 AM
Luca's Avatar
Luca
Lukesville
Default Speedo needle loves a wobble
What causes a speedo needle to wobble.
Old Jan 19, 2007 | 10:56 AM
antony215's Avatar
antony215
Escort Rs Turbo
Check your cable is pluged in properly at the back of the clocks.
Old Jan 19, 2007 | 01:31 PM
SafeChav's Avatar
SafeChav
Too much jelly
Old Jan 19, 2007 | 01:45 PM
Luca's Avatar
Luca
Lukesville
but i addded 42.5 ounces of blamonge and 12ounces of hundreds of thousands.
Old Jan 19, 2007 | 01:50 PM
SafeChav's Avatar
SafeChav
Then your fucked
Old Jan 19, 2007 | 01:56 PM
SafeChav's Avatar
SafeChav
I personally would just put it down to primitive mechanical instruments, that are 14-20 years old
Ive seen it on allsorts of makes/models of cars, it usually only wobbles within a certain speed, and is fine when below or above it
Old Jan 19, 2007 | 02:14 PM
JamboRS's Avatar
JamboRS
focus rs 1672
is there gear oil leaking from the shafts,fucked seals usually coz this
Old Jan 19, 2007 | 02:23 PM
Luca's Avatar
Luca
Lukesville
well its a new box in there well second hand-new , fitted it last night and noticed the needle wobble - autometer speedo is brand new so cant be that and its electrical not ford cable.
Have to check the seals tonight
Old Jan 19, 2007 | 03:12 PM
SafeChav's Avatar
SafeChav
Can't see seals making a difference - but obviously you will lose oil.
Odd
Old Jan 19, 2007 | 03:18 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Odd
anytime ive had a wobbly needle ive had a gearbox leak to go with it,mate replaced the diff seals(think it was those) and the wobbly needle stopped,
how is the actual speedo sensor in the gearbox operated?,is it fliud operated?
could explain it then
Old Jan 19, 2007 | 03:24 PM
SafeChav's Avatar
SafeChav
JamboRST, its gear driven off the differential.
That must just be purely co-incidental?!
Old Jan 19, 2007 | 03:30 PM
Luca's Avatar
Luca
Lukesville
I have heard it could possibly be the diff bearings causing this
Old Jan 19, 2007 | 03:38 PM
JamboRS's Avatar
JamboRS
focus rs 1672
im just going on what my mate told me,he's a ford mechanic and a very good one at that,as far as i know its a strip down to get to the seals
also have experienced it on other rst's also on my old diesel van
coincidence it may be but if it solves the speedo wobble then who cares
Old Jan 19, 2007 | 04:43 PM
SafeChav's Avatar
SafeChav
You don't have to go so defensive I was only saying aswell!
A wobbly needle can onyl really be caused by a worn instrument or a fluctuating output on the speedo drive. Hence why i can't see a leaky seal doing it.
Were you talking about the driveshaft oil seals?
Old Jan 19, 2007 | 04:45 PM
SafeChav's Avatar
SafeChav
Tell you what it could be, the speedo drive gear is nylon and they are prone to wear and snap teeth
Old Jan 19, 2007 | 05:18 PM
JamboRS's Avatar
JamboRS
focus rs 1672
wasnt gettin defensive,lack of smilies made it look that way,ill mind and add them in next time
not 100% sure what actual seal it is,ill try and get the info over the weekend if i see him,but its defo a strip down box job to get to them i mind that much
Old Jan 19, 2007 | 05:20 PM
SafeChav's Avatar
SafeChav
Would be interesting to see what you come back with, but i just can't see it being seals myself.
Old Jan 19, 2007 | 05:36 PM
JamboRS's Avatar
JamboRS
focus rs 1672
just off phone to him there,its not the diff seals,my mistake,its the diff bearings and says its only a matter of time before total failure and even more so if its gettin hammered
Old Jan 19, 2007 | 06:07 PM
antony215's Avatar
antony215
Escort Rs Turbo
One of these
http://cgi.ebay.co.uk/Ford-ESCORT-RS...QQcmdZViewItem
Could be that ive had a fucked one before and it made the needle go mad
Old Jan 19, 2007 | 06:13 PM
SafeChav's Avatar
SafeChav
Indeed one of those But theres 3 different colours, i duno which ones for which
JamboRST useful info
Old Jan 19, 2007 | 07:37 PM
Luca's Avatar
Luca
Lukesville
Well guys you have all been of help so it looks like a trip to ford in morning for a speedo drive, then if that doesnot solve it dif bearings here we come.
Mmmmmm and the advert said rebuilt 1000 miles ago lets hope so as the box i had was mint standard and rebuilt only got this one for the quaife diff.....
Old Jan 20, 2007 | 05:10 PM
SafeChav's Avatar
SafeChav
How badly does it wobble anyway, if your diff bearings were gone you would know about it mate
Old Jan 21, 2007 | 06:56 AM
JesseT's Avatar
JesseT
Usually, when the diff bearings wear out, the diff starts to move in directions it's not meant to. This will wear out the shaft oil seals and the plastic (red) speedo drive gear.
The speedo drive ger can be pulled out easily, so it's best to check tht first. If it's gone to a concave shape, then the bearings have definately gone.
Old Jan 21, 2007 | 10:49 PM
LeviA's Avatar
LeviA
Always found a wobbly speedo was due to one thing on Fords, lack of grease on the end which plugs into the back of the clocks. Take it out and grease it, replace it and it's should work perfectly.
tankybaby66
Feb 6, 2016 02:24 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
gingeRS
17
Oct 2, 2015 09:42 AM
