Something strange with vacum/boost
Hello
People on this forum advice me to connect boost gauge on vacum (left side on inlet mainfold). Before I have boost gauge connect after intercooler ( on aluminium "thing" ,sorry bad english). If I connect it on vacum, in idle I have abput -0.6 and when I boosting boost dont want go under 0.1 bar, But if I connect gauge after IC , I have boost 0.7.
Any ideas?
thanks
Any ideas?
thanks
Somethings not right.
if you connect a boost gauge before the throttle you will not see any vacuum, only boost.
If you connect it after the throttle plate, you will see boost and vacuum.
"""""f you connect a boost gauge before the throttle you will not see any vacuum, only boost.
If you connect it after the throttle plate, you will see boost and vacuum.""""
yes. but in 2nd case, I have vacum on idle, but when I boosting hard I dont have boost under 0.2 bar, and when I relase throttle boost fall in vacum suddenly.
why? I test actuator and he is holding about 1 bar- no weak spring
look this :
""" Some FPRs also take a vacuum feed from the manifold and increase the fuel pressure as the load increases. With a properly mapped ECU the vacuum function becomes surplus to requirements and can me removed."""
Deos this mean that I must connect fuel pressure regulator to inlet mainfold (right pipe) ?
look this :
Your making this far more complicated than it has to be!
By connecting your boost gauge behind the throttle plate, do you expect boost to continue entering the plenum when the throttle plate is closed?!
NO - thats physically impossible!
Ok I know that I complicated too much, but thats just because I have no idea for some thing which makes me
"...do you expect boost to continue entering the plenum when the throttle plate is closed?!" No and this is not my problem. you didnt understand my bad english.
when I connect boost gauge to pipe after intercooler (aluminium thing which goes from IC to engine) I dont have vacum but I have boost 0.7 bar. BUT when I connect boost gauge to inlet mainfold I have idle at vacum but when I driving hard in 4th gear or 3th gear and push throttle hard I have only 0.2 bar boost maximum! why?
."...do you expect boost to continue entering the plenum when the throttle plate is closed?!" No and this is not my problem. you didnt understand my bad english.
