nock on front driver side???
Old Jan 16, 2007 | 09:17 PM
cosworth_wannabee's Avatar
cosworth_wannabee
Default nock on front driver side???
right...there was a nock on my front driver side when i accelerated and decelerated, and when i bought the car the guy said it was the wishbone/balljoint/bottom arm. so ive replaced that and it hasent worked. ive asked a few people and someone said something about engine mounts, which i cant see it being cos it only makes the nock when the car is in drive and moving...i.e....if the handbracke is up and i try and move there is no nock. other than the wishbone, what could it be?? cheers people.
by the way its a mk5 escort.
thnx for answering all my questions u lovely lot...ur all ace
Old Jan 16, 2007 | 10:00 PM
slickescort1981's Avatar
slickescort1981
it does sound like engine mount/s but if only does it whilst drivin i would have said bottom arm. seein as replacing that hasnt worked have u tried the anti roll bar? sometimes the link bars go which causes a knock or more often the anti roll bar bushes, if u can move it side to side etc then they need replacing anyway, hope it helps.
Old Jan 17, 2007 | 05:23 PM
cosworth_wannabee
nice 1 m8 will have a look
Old Jan 17, 2007 | 06:40 PM
antony215's Avatar
antony215
Escort Rs Turbo
Could be cv joint
Old Jan 23, 2007 | 03:21 PM
Jay1975's Avatar
Jay1975
check 2 c if the engine has alot of movement under load i.e handbrake on and try pulling away, bonnett open so a m8 can tell u how much the engine moves. if more movement is detected pretty sure engine mounts
jessie_rs
11
Jun 3, 2019 04:57 PM
Derek Burleigh
Sep 16, 2015 06:27 PM
djmca
Aug 20, 2015 08:26 AM
Palethorpe01
15
Aug 18, 2015 06:09 AM
RIB1122
Aug 12, 2015 08:51 PM
