piper 285t2 cam
Old Jan 14, 2007 | 08:00 PM
rs230's Avatar
rs230
Default piper 285t2 cam
can you get away with just putting the cam in or do u need the full kit??
Old Jan 14, 2007 | 08:04 PM
swerv's Avatar
swerv
you need the springs and you need new lifters anyway.
then you may as well change the seals, so yeh whole kit
Old Jan 14, 2007 | 08:05 PM
rustyrs's Avatar
rustyrs
dont get a t2 there shit
Old Jan 15, 2007 | 09:36 PM
cabbyturbo's Avatar
cabbyturbo
iv herd no one likes them on here whats so wrong? iv got kent 35 are thay any good????
Old Jan 15, 2007 | 09:43 PM
Andy_R's Avatar
Andy_R
Nothing wrong with T2's IMO I ran one for a while and thought it was a great Cam. I've also seen good results with other cars fitted with them over the years. Where the "they are shit" comments come from I dunno
The Kent CVH35Cam is a great cam.
Old Jan 15, 2007 | 09:48 PM
cabbyturbo's Avatar
cabbyturbo
what other good cams are there????
Old Jan 15, 2007 | 10:01 PM
Andy_R's Avatar
Andy_R
Really all depends on the spec of the car.
knowledge = power when it comes to instaling & setting up cams IMO.
Old Jan 15, 2007 | 10:08 PM
cabbyturbo's Avatar
cabbyturbo
i have great respect for your knowledge but i guess i need to no a good cam to build good spec........and never forget you only get one chance to make the first impression!
Old Jan 16, 2007 | 03:10 PM
jimmylaud's Avatar
jimmylaud
ive had two t2 kits only seemed to last two months if i was lucky the tappets would stick and the cam would wear out ive been told this is because piper does not use new cams there are just reprofiled not 100% on that one tho
Old Jan 16, 2007 | 03:21 PM
JamboRS's Avatar
JamboRS
focus rs 1672
i had a piper in my erst and frst without any probs,but and its a BIG BUT,ive seen 2 cams on my mates car with less than 5k miles on each that were very badly worn(ones sporting your newman cam andy,oh and made 10bhp@wheels more at 1k less rpm),so much that they were scrap,also my mates is starting to get a little top end noise and it was a brand new piper put in it(guess what that will be)as a cam i think its a good one for top end power but there quality over the last couple of years has been poor,still ive had no probs with them but wont be going back to piper anyway
Old Jan 16, 2007 | 03:36 PM
SafeChav's Avatar
SafeChav
1. You need the full kit, no 2 ways about it
2. Get a CVH35, Piper cams for a CVH are rubbash
Old Jan 16, 2007 | 05:09 PM
LEE-RS's Avatar
LEE-RS
Custom
yeah i had that cam off you was still running good 8k after when i took it out
i think it just depends if you get a good one or a bad one same with the kent ones really
Old Jan 16, 2007 | 05:12 PM
SafeChav's Avatar
SafeChav
i'd say its more down to how well the engines been maintained and how much you rev the fuck out of it
Even standard cams are prone to wear, but my run about Orion is about to roll over onto 110k and its got its original cam, its tapping a little bit, but has done very well.............
Old Jan 16, 2007 | 06:27 PM
Oranoco's Avatar
Oranoco
Go with a Kent CVH35 or a Nemwan. Piper's 285T2 sacrifices everything in the midrange to give a small blip more at the top end.
Drive cars back to back with the 285T2 and then with the CVH35 and you won't be fitting the Piper offering.
Old Feb 22, 2007 | 07:01 PM
slimwynn's Avatar
slimwynn
could any one tell me whats the difference between the kent cvh34 and the cvh35
Old Feb 22, 2007 | 08:47 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Newman is the only cam that has managed to keep it's lobes in my engine. Much harder to fit and set up, but well worth it.
Piper and Kent are toilet.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
