Peugeot 205 with 4wd cosworth engine and running gear.
Old Jan 13, 2007 | 11:19 PM
muppet's Avatar
muppet
Default Peugeot 205 with 4wd cosworth engine and running gear.
Some people may remember this car was featured in maxpower in 1996 iirc. The car was originally converted by JDMotorsport.
I've actually had this car for a while now and it looked very dated when I 1st bought and hadn't really changed much from when it was featured in maxpower.
Here are some pics of it when I 1st bought it.
more to follow
Old Jan 13, 2007 | 11:22 PM
muppet's Avatar
muppet
I've actually had this car for a while now and bought it with the main conversion already done but it looked very dated and hadn't really changed much from when it was featured in maxpower. When I 1st got the car I had to wait until I had had my garage built as I had just moved and needed to make sure I could afford to get that done 1st. Once it was completed I then made a start on the pug.
The 1st jobs were to sort the interior of the car out by ditching all the amps and subs and making the dash look more subtle. Then I had to
Fit rollcage
Fit Ali fuel tank and
Locate battery in the boot.
Fit a automatic fan as it is manually operated.(probably run it of the spa gauge)
Fit Profec B spec 2 boost controller
Fit Spa digital water temp and oil pressure gauge.
Fit Harnesses.(old seats will stay for now but may change them at a later date.
Old Jan 13, 2007 | 11:23 PM
muppet's Avatar
muppet
muppet's Avatar
muppet
Old Jan 13, 2007 | 11:24 PM
muppet's Avatar
muppet
Old Jan 13, 2007 | 11:25 PM
muppet's Avatar
muppet
Ever since I have had the car it hasnt wanted to straighten up on its own so once all the above work had been done we started to do some work to improve it. We measured the castor angle and found that it was 2 degrees so after overhauling the column we wanted to increase the castor angle as much as possible. Unfortunatelty the bottom arm was already mounted as far as possible on the anti rollbar so we were left with 2 options. Move the top mount or move/extend the anti rollbar. After having a look around decided to buy blanks eccentric top mounts and cut the inner wing to move the centre point as far back as possible.
heres some before pics.
Old Jan 13, 2007 | 11:26 PM
muppet's Avatar
muppet
after pics.
these were bought but blank versions.
Once this was done he castor is now at 3.5 degrees. We were hoping to get more than that considering we moved the top mount by about 20mm but we werent surprised as I had done a few measurements before hand and thought it would only gain 1-2 degrees due to the length of the strut. Also we overhauled the steering column fitted a recon rack and also found the column was tight when going onto the rack so sorted that out and now seems as a lot better.
wide ka's Avatar
wide ka
look awsome i take it it was djmotorsport the same people who do the ka's
Old Jan 13, 2007 | 11:31 PM
CraigoScott's Avatar
CraigoScott
this looks a cool project, will be interested to see what you do to it styling wise to stop it looking like such a piece of shit!! :P
muppet's Avatar
muppet
Eventually I decided on a new set of wheels. I couldn't think of what would go with the car so ended up getting a set of compomotive TH's refurbed.
Old Jan 13, 2007 | 11:32 PM
muppet's Avatar
muppet
yep
Old Jan 13, 2007 | 11:46 PM
muppet's Avatar
muppet
Unfortunately it failed the mot just before christmas for the steering rack so replaced this along with a new rad and repalced all the front bushes for powerflex ones. I have still got the rear to do.
Old Jan 14, 2007 | 03:54 AM
AndyNo1's Avatar
AndyNo1
Old Jan 14, 2007 | 05:33 AM
GARETH T's Avatar
GARETH T
really cool machine
Old Jan 14, 2007 | 10:52 AM
kennyken's Avatar
kennyken
I remember reading this in my youth!
Old Jan 14, 2007 | 10:59 AM
Bullett's Avatar
Bullett
that was an awesome car, cant beleive its still about.what a beast.
i wouldve left it as it was just because it was old skool.
but still it looks lovely mate.and the th's look sweet on it.
Old Jan 14, 2007 | 11:06 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
I love the new wheels
Old Jan 14, 2007 | 11:19 AM
tracktoy's Avatar
tracktoy
have to agree with the above- love the new wheels
Old Jan 14, 2007 | 11:36 AM
DiscoStu's Avatar
DiscoStu
I'v seen this car in the flesh!! Hell of alot of work gone into it
And loving the new wheels, has a kind of integrale look to it
Old Jan 14, 2007 | 02:17 PM
richard_syko's Avatar
richard_syko
What a machine
Old Jan 14, 2007 | 02:31 PM
s1-boy's Avatar
s1-boy
yep im liking the new wheels mate !
Stavros's Avatar
Stavros
DEYTUKURJERBS
fantastic car, good call on increasing the castor too
Old Jan 14, 2007 | 03:41 PM
AX Cossie's Avatar
AX Cossie
awesome car, another french cossie coming soon!
Old Jan 14, 2007 | 03:43 PM
rapidcossie's Avatar
rapidcossie
please put the back windows back in
Old Jan 14, 2007 | 04:05 PM
muppet's Avatar
muppet
Thanks for all the comments.
I'd love to put the back windows in but it has always been a van and its a much bigger job than I 1st anticapted. Its something I have always planned on doing just a bit more grief than I thought. I have even got the windows and rubbers ready to do it just havn't had the courage to start.
Old Jan 14, 2007 | 04:16 PM
Blimey remember this from years back ,looks so much better on the new rims ,like how you have done them looks like they have the brake fins fitted
Old Jan 14, 2007 | 04:41 PM
rapidcossie
i almost bought a rsturbo van years ago...at the time i looked into having the back windows put back in by a body shop..
was only a couple of hundred pounds if i remember right?
Old Jan 14, 2007 | 05:05 PM
Eddie RST's Avatar
Eddie RST
That is awesome love the comps! Proper hard car
Old Jan 15, 2007 | 03:11 PM
COSSIE CAL's Avatar
COSSIE CAL
looks mint now lol but it looked like a real shed back in 96
Old Jan 15, 2007 | 03:26 PM
carlo's Avatar
carlo
Like that alot
Old Jan 15, 2007 | 05:03 PM
T4KAF's Avatar
T4KAF
looks mint on the comps,remember that in max power!!!
Old Jan 15, 2007 | 09:47 PM
Andyrs1800's Avatar
Andyrs1800
I have a old mag sumwhere with this car for sale in the back, its great to see these oldschool cars are still going, so many get crashed/broken oir ruined, Nice work
Old Jan 15, 2007 | 10:03 PM
NUTS RuS's Avatar
NUTS RuS
Whats the other car ?
Old Jan 15, 2007 | 10:20 PM
muppet's Avatar
muppet
It is something I would very much like to do so it will probably happen at some point. I havent decided what I will do with the rear end yet either so will proabably get it all done at the same time. I have bought a dimma style rear wing but not sure if that might be a bit ott or not.
Old Jan 15, 2007 | 10:27 PM
muppet's Avatar
muppet
thats my friends car.
https://passionford.com/forum/viewto...539150#3539150
Old Jan 15, 2007 | 10:56 PM
NasRs's Avatar
NasRs
Cappy
Like this, the new wheels look tough, give it the group b look somewhat!! Keep up the good work mate!
Old Jan 15, 2007 | 11:20 PM
Spiky's Avatar
Spiky
new wheels are awesome dude
looks well sweet
Old Jan 15, 2007 | 11:31 PM
massivewangers's Avatar
massivewangers
I think it looks awesome
All I'd change is the mirrors for something more racey and the side repeaters cos oval ones don't suit the angular looks of the car. Oh, and the T16 badges, cos it ain't
Apart from that, the new wheels have made it look a proper weapon
Old Jan 16, 2007 | 09:14 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Definatley heading in this right direction with this one
Old Jan 16, 2007 | 09:45 PM
OvaBoost's Avatar
OvaBoost
Would that mean it would corner better due to the outside wheel being flatter to the road?
