SPA dual boost & oil pressure 52mm gauge - SOLD
Old Jan 11, 2007 | 01:48 PM
Red16's Avatar
Red16
Default SPA dual boost & oil pressure 52mm gauge - SOLD
its currently on ebay, heres the link
http://cgi.ebay.co.uk/ws/eBayISAPI.d...5997&rd=1&rd=1
Old Jan 11, 2007 | 06:41 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
how much do you want for it to end the auction early, and why wont you post it?
Have just seen that you will post it now
Old Jan 12, 2007 | 01:48 PM
Red16's Avatar
Red16
yeah i fucked up with the postage when listing the item, now someones bid on it i cant change it, so i just added it into the description
Ł130 to end early
Old Jan 12, 2007 | 01:51 PM
Dan's Avatar
Dan
Benny boy, did you find out what colour the back light was?
Old Jan 13, 2007 | 01:29 AM
Red16's Avatar
Red16
not powered it up, but instruction booklet says you can select red/green
Old Jan 14, 2007 | 09:21 AM
Dan's Avatar
Dan
Not Blue aswell then like the other one's we looked at?
Old Jan 14, 2007 | 09:30 AM
rapidcossie's Avatar
rapidcossie
there is two pressure sensors with that one...
you sure its oil temp and not oil pressure?
Old Jan 14, 2007 | 01:25 PM
Red16's Avatar
Red16
dunno Dan, i'll try n power it up when i get a chance n see what colours you get.
the Demon Tweeks part number shows up as being the part number for oil temp and boost pressure gauge, i'll find out what it is. ive never used it, got it from a friend of a friend who said it was oil temp and boost pressure.
Old Jan 14, 2007 | 01:41 PM
rapidcossie
is there a small gold sensor that looks like the temp sensor that goes into the head for coolant temp?
just to let know there is about 100 quid of difference in price between the one you state it is and the boost and oil press
Old Jan 14, 2007 | 02:53 PM
rabmc's Avatar
rabmc
Looks quite had to fit euan , is it ?
Old Jan 14, 2007 | 03:14 PM
rapidcossie
nah its not mate..
only three wires. L N E
the rest plugs into the back of the gauge and then runs to the sensors.
depending where the sensors go they need to be drilled and tapped
Old Jan 15, 2007 | 06:59 AM
Red16's Avatar
Red16
nope, cant see that sensor you mentioned, checked the part numbers on the sensors and they both appear to be for pressure so must be a boost/oil pressure gauge, will power it up later today and see what the gauge displays.
cheers
Old Jan 15, 2007 | 05:50 PM
rapidcossie
scored there mate as the dual press gauges are the most expensive
Old Jan 15, 2007 | 07:16 PM
Red16's Avatar
Red16
its oil pressure and boost pressure, just checked the wiring loom and it says BOOST PRESSURE on one plug and OIL PRESSURE on the other plug
Old Jan 15, 2007 | 07:32 PM
Red16's Avatar
Red16
item now relisted again as boost / oil pressure dual gauge
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=280071001430
JK12
33
Apr 26, 2021 12:09 PM
mint_s2
Sep 2, 2015 08:58 AM
YODI
Aug 30, 2015 01:12 PM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
