1.9 american tall block cvh engine for sale...
up for sale, my 1.9 american tall block cvh engine. it was built by euro engines in essex, has only covered 10k miles since fiiting. took it to power engineering last saturday where it made a very respectable 185bhp and 208lb/ft of torque on a standard cooler. has since been fitted with a paddle clutch which is also included. engine is still in car at the mo so any potential buyers are welcome to come and check it out... am selling due to engine and management upgrade...
07 Specification : The engine is based on the American 1850 "tall" block assembly which we modify to fit in place of any of our European CVH 1300, 1400 and 1600cc (but not 1800) engines
Cylinder Block : Overbored, then each bore cross hatch honed to suit each individual piston. Block face is then skimmed, completely stripped of oil gallery and core plugs. Pressure tested and thoroughly cleaned. All main bearing housings checked for ovality and line bored where necessary. Choice of bore sizes : 82.5, 82.75 or 83mm (1905 cc)
Crankshaft : American 88mm stroke. Small big end journal type. Specially developed by Ford to reduce friction. Giving gains in strength and reliability.
Oil Pump : New high flow late specification.
Con Rods : American, modified.
Pistons : 83mm American, modified.
Camshaft : XR3i profile. New followers.
Head Gasket : Heavy duty - Felpro.
Cylinder Head : Modified European. Completely reconditioned, valve guides replaced, valves and seats refaced/recut or replaced as necessary, new springs, seals and surface ground.
The complete engine includes all the above, plus reconditioned sump , pick-up pipes, new timing belt, new gaskets and cylinder head bolts. Each engine is hand built and the sole responsibility of one engine builder
SALE IS FOR BARE ENGINE WITH CLUTCH ONLY NOW...
sensible offers please!!!
any questions, joe 07977003022
below is a link to a quick vid of engine havin a little rev, you'll see its pretty smooth... please excuse the slightly blowing exhaust!!!
http://s93.photobucket.com/albums/l5...t=MOV03985.flv
could do with a new rocker cover gasket...
Originally Posted by Alex zvh cabrio
i got the same engine in my garage cant sell it for love or money
Zoggon
Aug 10, 2015 10:39 AM
