wasted spark help
Old Jan 4, 2007 | 08:03 PM
crash_ash's Avatar
crash_ash
Default wasted spark help
Fitted wasted spark driver into my redtop L8 ECU, modified my rev counter, but the rev counter doesn't work, i've bought a stack rev counter and that too reads zero. Everything else works fine. I've checked contiunuity between the ecu pins and the driver board to eliminate the possibilty of dry joints.
It is wired as follows
26 (cut) - Blue
25 (cut) - Purple
24 - Brown
21 (cut) - Grey
20 - Orange
Any Ideas ?
Old Jan 4, 2007 | 08:59 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Have you removed the surpressor that is on the green wire in the engine bay, and then connected the wire ends together?
(IE - green wire to surpressor then to green wire, remove surpressor so you have green wire to green wire)
This surpressor can be found where the coil used to be
Old Jan 4, 2007 | 09:00 PM
Graceland's Avatar
Graceland
Team HOTHOT!
PS - you should have no need to be touching the wiring to the driver board in the ecu itself - this is all done in house at MSD when it is fitted
Old Jan 4, 2007 | 09:09 PM
The DIVA's Avatar
The DIVA
You have P25 and P26 transposed.....
Blue= P25
Purple= P26
And if you have an iss 1 board,there is a mod for the revcounter...
Old Jan 4, 2007 | 09:51 PM
crash_ash's Avatar
crash_ash
fitted board into ecu myself, i was confused about pin 25 and 26 the instuctions said
Blue= P26
Purple= P25
but the photos of what it should look like showed
Blue= P25
Purple= P26
so i followed the text, also i've eliminated that being the problem as pins 25 and 26 are described as
P26 = Coil (1+4)
P25 = Coil (2+3)
therefore jumbling these two would make it not run it describes pin 21 (grey) as the tacho output.
I only bought it a couple of weeks ago, but it is a version one (what difference is V2?)
I've modded the tacho, and bought an aftermarket one, still no joy.
HOWEVER
When i removed the suppressor on the green wire to the coil i didn't connect it back together (didn't think they'd be needed) So i'll undo all the loom tape and untidy the loom and try that, sounds like the probable cause
Old Jan 4, 2007 | 09:53 PM
Stu @ M Developments's Avatar
PassionFords Creator
That is most likely teh solution here.
Old Jan 4, 2007 | 09:55 PM
Sorry Fella, replied at teh same time as you.
The 25 & 26 picture is now fixed, and i will add a line clarifying that teh greens need reconnecting.
That green is the tach wire from 21 to your teach head.
Old Jan 4, 2007 | 09:56 PM
crash_ash's Avatar
crash_ash
feel a bit silly now, even considered setting the tacho to 2cyl and chopping the loom and driving the tacho off one of the coils, couldn't bring myself to do it.
Old Jan 4, 2007 | 10:02 PM
crash_ash's Avatar
crash_ash
aah, hence the "tacho is now driven off the ecu, not the coil" and the strange way to route a wire from the ecu to the dash?
that has made it clear now
Old Jan 4, 2007 | 10:04 PM
That will work just fine if you want to do that pal.
Yep, thats why mate.
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
DixieTheKid
Sep 14, 2015 09:04 PM
