Map sensor FRST
Old Dec 30, 2006 | 08:31 PM
munchy_blue's Avatar
munchy_blue
Default Map sensor FRST
My map sensor has gone down and was woundering if it is possible to use the 3 bar map sensor instead of a std one the engine is std at the mo but im going to be getting beige injectors and a 195 chip in the next few months .
thanks
Old Dec 31, 2006 | 10:20 AM
BEN FRST's Avatar
BEN FRST
It would be cheaper to use a 2.5 bar map sensor from an escort cossie this is what i use on mine as you will not run any more boost than 16 - 18 psi on a 195 frst chip
Old Dec 31, 2006 | 11:55 AM
Avinitlarge's Avatar
Avinitlarge
Default Re: Map sensor FRST
thanks
Depends on the management too, OFAB, Yes. OFAC, No
Old Dec 31, 2006 | 01:05 PM
SafeChav's Avatar
SafeChav
Pretty sure you'll need a chip to run anything other than a standard sensor, the MAP in the ECU will be wrong otherwise
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
