Are there 2 differnt part numbers 4 a bosch 044 fuel pump?
Guys, ive just recieved my Bosch 044 fuel pump but something doesnt look quite right about it, the part number reads 0 580 464 044 but there is no threaded union at the inlet end just a straight pipe for a hose connection? can anyone shed any light on this for me?
they come without the fitting kit m8 so you NOW need to get the fitting kit!
edited to say IF it's a Group A onbe that's used on the Cossie then it should say 0580254044 also!
you think so? it looks different to the others ive seen tho, the part number on mine is 0 580 464 044 and the ones advertised everywhere else are numbered 0 580 254 044. so something must be different??????
You may have been shipped a standard cossie one, the proper grp A jobbie has threaded connections both ends (M18x1.5 inlet and M12x1.5 outlet), not a push on inlet as they do on the std cossie pumps, if you asked for a grp A one then send it back!
0580464044 as standard on (from a Polish site) :
ALPINE A610 3.0 TURBO 03/91 -
ALPINE V6 2.5 TURBO 01/85 - 12/90
CITROEN CX II 25 GTI TURBO 2 09/86 - 12/92
PEUGEOT 505 2.2 TURBO INJECTION 03/84 - 10/88
PEUGEOT 505 2.8 GTI V6 06/86 12/93
RENAULT ESPACE II 2.0 (J636) 01/91 - 09/96
RENAULT ESPACE II 2.2 (J/637, J63G) 01/91 -09/96
RENAULT ESPACE II 2.2 4X4 (J/S637, J63G) 03/91 - 09/96
RENAULT ESPACE II 2.8 V6 (J638,J633) 01/91 - 09/96
RENAULT 21 2.0 TURBO , 2.0 TURBO 4X4 (L48L) 02/90 - 10/92
RENAULT 25 2.4 V6 TURBO (B295) 10/84 - 05/90
RENAULT 25 2.5 V6 TURBO (B29G) 01/90 - 12/92
RENAULT 25 2.8 V6 INJECTION (B29F) 06/87 - 12/92
RENAULT 25 2.8 V6 (B293) 06/87 - 02/90
not that much use to you then
Features:
1) Cross reference:
a) Bosch: 0 580 464 044
b) OE: 1450 70, 91 538 807, 1450 70, 91 538 807, 77 00 260 678
2) Applications:
a) Citroen: ALPIN A610 3.0 / V6 2.5 01.85-12.95 3L/2.46L
b) Peugeot: 505 06.86-12.93 2.85L
c) Renault:
21 SALOON 02.90-10.92 2L
25(B29_) 10.84-05.90 2.46L
ESPACE 01.91-10.96 2L
3) Pressure: 3bar
4) Shut-off pressure: 6bar
5) Wide open flow: 160L/h
6) Voltage: 12V
These are nowhere the flow rate of a 0580 254 044
The proper one will flow 228 L/h at 5 Bar and have a shut off pressure of 10 Bar
Also beware there are a lot of cheap Chinese made copies on the market now that unscrupilous traders are passing off as the real thing...
1) Cross reference:
2) Applications:
c) Renault:
3) Pressure: 3bar
6) Voltage: 12V
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
, time for a rant and a fuel pump return
