Is this a good price?
For a cossie engine to go into my rwd conversion.
Quote:
To use a good 205 block that we have at std bore now; and taking it to 0.5 rebore with pistons, new oil pump. all bearings and thrust washers, sump, front cover, good 4wd head, std cams, tappets, belt & tensioner. Basically a complete bottom end with head, cams and timed up ready to fit would be around £1500.
Then there are the ancillarys, 4x4 loom and ECU, starter, alternator, inlet, turbo, manifolds etc, probably be another 1500 or so id imagine?
sweet!Also been looking at this one complete for 2.5k
https://passionford.com/forum/viewtopic.php?t=240771
I can do you a engine on new 200 block longstudded new mahle pistons with valve cutouts rebuilt with all cometic gaskets inc triple layer head gasket rebuilt head with bd10 & bd14 cams with inlet plenum and 2wd manifold, alternater,starter and t38 from turbo dynamics engine and turbo have only done 1300 miles and was built by steve scott of A1 rally sport
track.focus'd
Aug 12, 2015 05:53 PM
