cossie pistons
Old Dec 27, 2006 | 05:12 PM
Basky's Avatar
Basky
Default cossie pistons
is there any way of tellin if they are 2wd or 4x4 ones
as they are in the car,the heads coming of soon and want to know if poss
the cars a 2wd but theres no slap,telling me they could be 4x4 ones
Old Dec 27, 2006 | 05:20 PM
marco polo's Avatar
marco polo
when did you damage your engine
Old Dec 27, 2006 | 05:23 PM
dave cos4x4's Avatar
dave cos4x4
you can tell when the head is off by the look of them.
Sure 4x4 got bigger bowls in the tops of the pistons.
they will have numbers on the edge of the pistons too telling you the size etc..
Old Dec 27, 2006 | 05:32 PM
Basky's Avatar
Basky
its not, im doin the head gasket
replacin with multilayer and was woundering,
got an oil leak from the gasket so decided to change ,along with the cam belt and other gaskets
Old Dec 27, 2006 | 05:34 PM
Basky's Avatar
Basky
so with 4x4 pistons in a 2o5 block does this alter the compression
Old Dec 27, 2006 | 05:37 PM
righthooker's Avatar
righthooker
only very slightly ,lower iirc
Old Dec 27, 2006 | 05:41 PM
...if you put 4x4 pistons in a 2wd block with std thickness head i beleive you get 7.8-1 or 7.9-1 cant remember
Old Dec 27, 2006 | 05:43 PM
Basky's Avatar
Basky
whats is the head mesurement
Old Dec 27, 2006 | 05:44 PM
dave cos4x4
have you still got the 2wd head on your car?
Old Dec 27, 2006 | 05:46 PM
Basky's Avatar
Basky
yes, its only done68k
its got a grpa(gasket) on the mo but not sure if been machined before
Old Dec 27, 2006 | 05:51 PM
dave cos4x4
so the comp will be a bit lower then with having the 2wd head mated to 4wd pistons.
Some people get away with just changing to the steel gaskets without skimming.
depends how thick your head is,best to check that first.
Old Dec 27, 2006 | 05:52 PM
Basky's Avatar
Basky
cheers dave,see you fri all been well
Old Dec 27, 2006 | 06:01 PM
dave cos4x4
Old Dec 27, 2006 | 09:52 PM
marco polo's Avatar
marco polo
Oh cool i thought you blew it up for a min
marco
Old Dec 27, 2006 | 09:56 PM
marco polo's Avatar
marco polo
see phil your wrong again
if you have got 2wd unskimmed head and 4wd pistons the compression ratio is 7:7:1 exactly no matter if it's in a 2wd block or a 4wd block
marco
Old Dec 27, 2006 | 09:59 PM
The DIVA's Avatar
The DIVA
marco
Was gonna say that,mine has had a tiny skim and is 7.78:1...
Old Dec 27, 2006 | 10:48 PM
...hence why i said i cant remember..it must be nice having reyland give you info ...i was .1 out and you give me shit
Old Dec 28, 2006 | 07:00 PM
marco polo's Avatar
marco polo
yes but that 1 could kill an engine
and for the record you would be susprised what i know about the yb engines i have had cossys and pinto powered cars all my life
i dont need martin to tell me what i know
cossy since 92 one of the first to have level 8 and pectel board tuned cossie in the country wire ringed /grp a gasket/ standard comp / yrs ago when you was shiting in your nappy
lenny with no hair
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
cossie330
Sep 27, 2015 04:13 PM
