What would cause this?
Old Dec 17, 2006 | 12:08 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Default What would cause this?
SOMETIMES I get a nasty vibration through the steering wheel when I brake. You can brake hard or gently, it is completely random. Now I'm thinking it is a knackered bush somewhere on the front end. I don't think it is warped discs, and I do hope that it isn't warped discs lol. APT hope that it is otherwise it's more bushes for them to fit.
Any ideas?
Old Dec 17, 2006 | 12:54 PM
craigos's Avatar
craigos
discs, worn rack ,sticky brake,bushes, strut tops,could be alsorts
Old Dec 17, 2006 | 01:01 PM
fast_ford_uk's Avatar
fast_ford_uk
*unbalanced wheel
*wheel bearing
*warped disc
*badly worn tyres
Old Dec 17, 2006 | 03:38 PM
Tony Turbo's Avatar
Tony Turbo
Oh, floppy discs! Not that simple then
Thanks guys
Old Dec 17, 2006 | 03:47 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Tone, remind me what pads you have?? I would say they are either glazed or they are too hard and you brake like a girl.
Old Dec 17, 2006 | 04:19 PM
Tony Turbo's Avatar
Tony Turbo
DS2500's...
The bloke that fitted the new bits to the back on Saturday reckons it is a bush, or suspension related. Something I want you guys to do when it comes back to you is have the front calipers taken apart and cleaned up as it has clocked up a few miles now.
You think there could be some shit in the calipers?
Old Dec 17, 2006 | 05:02 PM
NUTS RuS's Avatar
NUTS RuS
Clean them yourself you lazy c**t
You will be giving us Tonys a bad name
Old Dec 17, 2006 | 07:04 PM
Tony Turbo's Avatar
Tony Turbo
You don't have a dog and bark yourself
Old Dec 17, 2006 | 07:12 PM
craigos's Avatar
craigos
you do if you can?
Old Dec 17, 2006 | 07:32 PM
NUTS RuS's Avatar
NUTS RuS
That way you will learn things as you go along - so saves posting threads on a BB
My guess is a warped disc
Is it one side or both ?
Old Dec 17, 2006 | 07:50 PM
Christian and Beccy
#1 in Spelling Club
Tone, it's just the same as mine does. Try de-glazing the pads. Easiest and cheapest option, see if that makes a difference.
I still reckon you should try some standard compound pads for the road. Not sure how much you could pick a set up for, but got to be worth a go. You might be pleasantly surprised. Remember that 330mm discs and 4-pots are WAY overkill for a sub 1000kg car, so there is no need for lairy pads.
Fit standard pads, then if you can make them fade, try going just one step up.
Old Dec 17, 2006 | 08:49 PM
Tony Turbo's Avatar
Tony Turbo
Hmmmmm, you could be on something. If you get 5 mins tomorrow, you reckon you can get me a price on something please?
Old Dec 17, 2006 | 08:55 PM
Tony Turbo's Avatar
Tony Turbo
Originally Posted by craigos
you do if you can?
Possibly. I choose not to though.
I hope not
I don't know if it is one side or not, how can you tell? Cheers Tone
Old Dec 17, 2006 | 09:19 PM
NUTS RuS's Avatar
NUTS RuS
Jack the car up, press the pedal get out then spin the wheel.
If you get a catch, no catch noise, repeated during the spin bin the disc. They are almost impossible to recover once warped
Old Dec 18, 2006 | 08:52 AM
Christian and Beccy
#1 in Spelling Club
Tone, it is possible to DTI a brake disc. You attach a very accurate measuring device to a fixed point on the car, then place the 'probe' on the disc, then you spin the disc and it will tell you how far the disc runs out, it is incredibly accurate. We can do this.
As you know, the AP rotors are over £200 each, so fingers crossed its not that. Also, I'm not sure if I would replace them individually either.
I will see what I can find out regarding the pads. Can you remember the caliper number? Or failing that the part number of any of the pads you have had in the past for them?
Old Dec 19, 2006 | 11:59 AM
Tony Turbo's Avatar
Tony Turbo
Thanks Tone, if I get a chance this weekend I'll give it a whirl. Whirl... Get it?
Mr C - I have never bough pads for the calipers yet, they are 5200's. I wouldn't be too keen on replacing one side either, so £400 for a some discs?
Nice
Old Dec 19, 2006 | 04:54 PM
kurdt5's Avatar
kurdt5
i had this problem last month.
changed my disks and pads with no effect.
turned out the steering rack was knackered. £88 new rack now its a sweet drive.
Old Dec 19, 2006 | 05:58 PM
NUTS RuS's Avatar
NUTS RuS
Thats why doing some simple tests first helps
Hope its something easy cheap/simple, but remember you will have to change those discs/pads someday TT so start saving up
Big brakes always look fine until they need replacing
