What wiring for fuel pump
Old Dec 13, 2006 | 08:03 PM
JjCoDeX75's Avatar
JjCoDeX75
Default What wiring for fuel pump
Hi guys
I have bought some bits and pieces to improve the cossie, including a group A fuel pump.
My wiring is typically poor. I need advice on two things.
One - Where be the fuel pump relay for the saph rwd cosworth
Two - what wire to be used
Thanks guys
JJ
Old Dec 13, 2006 | 08:13 PM
Moonie's Avatar
Moonie
Use you existing fuel pump feed to trigger a relay. Run a wire directly from the battery through a fuse (near the battery) then through the relay and on to the pump. Also worth replacing the earth to the pump at the same time.
You will find all the bits on here...
http://www.vehicle-wiring-products.co.uk/
Old Dec 13, 2006 | 08:37 PM
JjCoDeX75's Avatar
JjCoDeX75
I like your thinking! Interesting. The only down side is that the fuel pump wiring is still a part of the system then, and I do not trust it. I dont mind re-wiring the pump, just not sure what gauge of cable to use.
JJ
Old Dec 13, 2006 | 08:43 PM
xr4x4rs's Avatar
xr4x4rs
from what ive read and i will be doing the same
you need a new power cable from battery to relay with fuse holder may aswell do earth aswell
trlay
you use the wire that goes from the inertia switch to you fuel pump
this is just to trigger the new really
you still use the original relay etc as its built into the engine loom
then from teh relay new wire is used to the fuel pump
you will have all new wiring bar 1 wire which is to trigger the new relay
theres a threard somewhere that someone did with a simple diagram
ill try and find it for you
Old Dec 13, 2006 | 10:00 PM
xr4x4rs's Avatar
xr4x4rs
i carnt find the post
take a look in technical section , sure theres a few post about them in there
Old Dec 14, 2006 | 08:48 AM
JjCoDeX75's Avatar
JjCoDeX75
Cheers matey!
I will probably do the same, though I must admit, my inertia switch was retired some years ago due to perpetual failure. I had a leaky boot, so you get the picture.
I will check the technical section. As you say, I recall Stu posting something. If I find I will put a url link for gold members.
JJ
JK12
33
Apr 26, 2021 12:09 PM
jonjg
Sep 1, 2015 03:46 PM
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
