Oil return pipe in sump
Old Dec 9, 2006 | 11:19 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Default Oil return pipe in sump
Hi there!
Has anyone ever welded an oil return pipe into the sump of an CVH?
I'm planning to equip my modded XR3i Efi with a Turbo running very low boost pressure (4 or 5 PSI) and I don't want to remove the block.
Old Dec 10, 2006 | 10:48 AM
charlieboy's Avatar
charlieboy
you just drill & tap into block near oil filter as i remember!
Old Dec 10, 2006 | 12:01 PM
Rick's Avatar
Rick
Make sure it's as high as possible on the sump - so well above oil level. The pipe return pipe should be as bend free as possible, so it drains away easily.
Old Dec 10, 2006 | 02:20 PM
marky_g's Avatar
marky_g
Fleet Manager
tap the front of the block where u'd find it on rst
Old Dec 10, 2006 | 09:57 PM
user 7082039239
That's what I'd like to avoid. Don't want to remove the engine.
My plan is to just put a oil lubricated/cooled turbo from a S1 on and run some very low boost. Maybe even without an intercooler, as simple as possible. And therefore the sump would be the easiest option.
Old Dec 11, 2006 | 10:10 PM
marky_g's Avatar
marky_g
Fleet Manager
spend time doin the properly now and less repairing i later
Old Dec 12, 2006 | 01:35 AM
fezzajsy's Avatar
fezzajsy
yep
Old Dec 12, 2006 | 03:11 AM
SaqsS2turbo's Avatar
SaqsS2turbo
thats wot ive done at the mo 6psi and its going ok lol
Old Dec 12, 2006 | 03:12 AM
SaqsS2turbo
i may hav a pic of how i done it on my sump let me check
Old Dec 12, 2006 | 03:16 AM
SaqsS2turbo
there ya go maty
Old Dec 12, 2006 | 03:18 AM
SaqsS2turbo
i just grinded out the nipple from a old rocker cover i had lying around and welded it in from both sides
Old Dec 12, 2006 | 11:31 AM
GraphiteGray's Avatar
GraphiteGray
Turbo Technics used the same method for their oil return on the XR3i Turbo conversion
Heres some pics of my TT sump
Old Dec 12, 2006 | 05:27 PM
steven botes's Avatar
steven botes
can be done
i braised a 1/2" hydaulic fitting into the sump - keep it as high as possible
Old Dec 12, 2006 | 08:06 PM
user 7082039239
Yeah, that's exactly what I'd like to do. Now I know that it's possible. Cheers for all the pictures, guys!
Old Dec 13, 2006 | 12:05 AM
SaqsS2turbo
is that low comp pistons fitted from a rst lump or ?
Old Dec 13, 2006 | 05:23 AM
SirG's Avatar
SirG
Looks like std. CVH pistons. Non-turbo
Old Dec 13, 2006 | 11:32 AM
GraphiteGray
Yep standard 16i bottom end, now replaced by newly rebuilt all singing all dancing S2 bottom end
Old Dec 13, 2006 | 05:31 PM
SaqsS2turbo
sweeeeeeeet
Old Dec 13, 2006 | 08:58 PM
user 7082039239
Did Turbo Technics lower the compression ratio at all? 16i had something round 10:1 if I remember correctly, quite high actually.
Old Dec 13, 2006 | 10:12 PM
GraphiteGray
They used the standard compression, the only mods they did was bolt a turbo on and fit a special advance/retard distributor, 5psi max
Old Dec 17, 2006 | 06:35 PM
MarkN's Avatar
MarkN
Default Re: Oil return pipe in sump
This is exactly what I want to do to my EFi Mk3 Escort. The mechanics seem quite simple but I don't know what to do about the management side of it.
Would FRST management work in a low-boost system with the actuator adjusted accordingly? Or would you have to go for an after market ECU?
Old Dec 22, 2006 | 02:27 PM
user 7082039239
I guess FRST management would work. However I'd like to know if you can run low boost even with the normal EFI management which is actually designed for N/A engines.
Old Dec 22, 2006 | 02:28 PM
user 7082039239
Thanks for the information! Tis making me more and more confident that it'll work in the end.
EDIT: One more thing. Does anyone know some hp figures for such a TT converted 1600i?
Old Dec 22, 2006 | 05:07 PM
SafeChav's Avatar
SafeChav
Originally Posted by SaqsS2turbo
Is it just me, or is that actually pointing downwards slightly
Old Dec 22, 2006 | 05:10 PM
SafeChav's Avatar
SafeChav
I thought i already answered that question on your thread....?
https://passionford.com/forum/viewto...light=#3448314
Old Dec 22, 2006 | 05:24 PM
SaqsS2turbo
was slightley tilted but i got a ful rst engine and running gear to go in so all gud
Old Dec 22, 2006 | 06:15 PM
user 7082039239
Just one more question: Will the N/A EFI management be able to handle a low boost pressure of lets say 5 psi? Or will I need a FRST loom?
Old Dec 22, 2006 | 06:41 PM
SafeChav's Avatar
SafeChav
Thats very very bad mate
May not seem it, but it is
Old Dec 22, 2006 | 06:43 PM
SafeChav's Avatar
SafeChav
Not so much the wiring, but you need to change management. you could plug an OFAC ECU and MAP sensor straight in, or OFAB with a couple of very minor and easy to do wiring changes.
Old Dec 22, 2006 | 06:45 PM
SaqsS2turbo
dnt wrry that engines not gnna be turbo'd again
Old Dec 22, 2006 | 06:57 PM
user 7082039239
Yeah I know. But do you think that the std N/A EFI won't work for low boost?
Old Dec 23, 2006 | 01:08 AM
SafeChav's Avatar
SafeChav
No.
Well, yes, but expect it to run like poo, and make sure you have a good level of RAC/AA cover...................
Old Dec 23, 2006 | 01:12 AM
SaqsS2turbo
try 14psi for a 5 mins run round the block to dodgy but was fun LOOOL luckeley i didnt blow a piston
Old Dec 23, 2006 | 08:00 AM
user 7082039239
No.
I've got my own towing truck, so that's not a problem!
OK, looking for an ECU, MAP-Sensor and Charge temperature sensor off an FRST now.
Old Dec 23, 2006 | 02:19 PM
SafeChav's Avatar
SafeChav
No.
Thats better
The ECU & MAP will be easy, the ACT is available from ford. Your guna be a bit stuck when you come to find a reducer for the ACT though
Old Dec 24, 2006 | 10:06 AM
MarkN's Avatar
MarkN
Yep you did. But if you check the dates I asked the question here before starting my own thread...
Thanks for all your help BTW
Old Dec 24, 2006 | 02:43 PM
SafeChav's Avatar
SafeChav
Smart arse
155lee
Oct 27, 2015 04:55 AM
little bram
Sep 21, 2015 02:50 PM
Chopshop85
Sep 18, 2015 06:13 AM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
