what compression ratio on a 2.0 zetec turbo
Old Dec 5, 2006 | 09:50 PM
escrst's Avatar
escrst
Default what compression ratio on a 2.0 zetec turbo
hi just been to my engine builder and he rekons on somthing around 9-1
im not sure if this is too high but they build reliable race engines and obviously he knows more than me.
we want to run a maximum of 2 bar boost and its got cams pistons rods all the arp bolts and stuff that goes with it autronic sm2 managment etc wot u guys rekon
Old Dec 6, 2006 | 06:56 AM
sas's Avatar
sas
should be good!
The problem with running a higher CR is detanation, so aslong as you are running a proper ECU the mapper will be able to retard the ignition at med to high boost to prevent it.
I run 8.8:1 in my ZVH.
PS dont forget the extra loading on the head gasket at that CR and boost.
Simon.
robnock
21
May 13, 2019 05:29 PM
cossirob
Aug 29, 2015 03:23 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
