Cossie Problem
Old Nov 27, 2006 | 10:53 PM
llw's Avatar
llw
Default Cossie Problem
right was on the motorway last night
got off on the slip road
driving home, hit boost and the car started missing/hesitating and making a ppuuuurrrrrpppppp sound
i thought wtf parked up opened bonnet everything seemed ok, carried on going but it was the same
got home took out the plugs, the 3rd plug had its tip missing and was fcuked
so woke up today put in new plugs and leads (to be on safe side)
still same problem, so i thought ive changed everything why not change the fuel filter too, but still same problem
done a compression test, 1,2,4 cyl. are coming up with a reading of 10, but 3rd cylinder is coming with a reading of around 8
anyone know what the problem could be
engine sounds still sweet, absolutely no smoke
all feedback shall be appreciated
Old Nov 28, 2006 | 12:57 AM
jon@work's Avatar
jon@work
unfortunately sounds like it's time to take the head off - I bet your piston isn't looking particularly happy
Old Nov 28, 2006 | 07:45 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Ouch
Old Nov 28, 2006 | 09:46 AM
Smoker's Avatar
Smoker
Default splutter
think its time for a rebuild m8
Old Nov 28, 2006 | 10:29 AM
llw's Avatar
llw
Default Re: splutter
a 400brake rebuild to kill all u masers
Old Nov 28, 2006 | 10:30 AM
llw's Avatar
llw
someone has told me that the tip of the plug has marked the valve?
anyone think this can be true
Old Nov 28, 2006 | 11:02 AM
Smoker's Avatar
Smoker
Default chachi power!
Old Nov 28, 2006 | 11:03 AM
jon@work's Avatar
jon@work
more likely it's the piston - either way it's time for the head to come off
Old Nov 28, 2006 | 01:44 PM
llw's Avatar
llw
but if it was the piston
wouldnt it be smoking badly and idling funny etc
Old Nov 28, 2006 | 07:09 PM
jon@work's Avatar
jon@work
not if the oil control ring and piston area either side of said ring is OK
Old Nov 28, 2006 | 08:03 PM
jam06's Avatar
jam06
the same thing happened to me and that ended in a rebuild
Old Nov 29, 2006 | 12:43 AM
reisskahn's Avatar
reisskahn
Bad news about the car mate, hope its nothing too serious.....
What exactly happend and what damage was there when the head came off for inspection??
Thanks.....
Old Nov 29, 2006 | 08:18 AM
James_RScos's Avatar
James_RScos
That sounds right to me thats why you would be down on compression i bet the top of the piston will be pitted like loads of small dents in it and then the bit of plug tip has got in the valve and marked it or bent it a little when its come down and traped the plug tip,
I think the same happened to my mates car.
Best have head off and have a look TBO.
Old Nov 29, 2006 | 04:57 PM
rabmc's Avatar
rabmc
Simalar thing happened to me mae at high speed , took plug out with no tip
Here was the result , smoked badly after it happened , its now a brilliant pen holder
heres what i found
good luck , hope its not as bad as this
Old Nov 29, 2006 | 05:28 PM
trevCOSS's Avatar
trevCOSS
it will be a melted piston for sure, ame symptoms on mine when I melted one.
Old Nov 29, 2006 | 06:36 PM
dilo_attax's Avatar
dilo_attax
heres what i found
oooo that looks bad! its gnna cost a bob or 2..... hope ur free with ur poket! lolz
Old Nov 29, 2006 | 08:03 PM
silky16v's Avatar
silky16v
Get on That!
same thing happened on my escort cosworth took head to find that the exhaust valve had a piece missing outta it no damage to piston though
take head off and look at valves and have them all check and lapped back while its off
if it hole in piston it'll be obvious enough
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Thanasis
Sep 7, 2015 07:33 PM
routemaster
Sep 7, 2015 05:27 PM
