Injector help
Old Nov 27, 2006 | 12:15 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default Injector help
just started the car up and for some reason theres petrol pissing outta the 1st injector where it goes into the fuel rail, will this just be the rubber o ring or could it be anything else?
btw its a 2wd Saff
Old Nov 27, 2006 | 12:16 PM
SapphyMike's Avatar
SapphyMike
probably the o-ring if the rail hasnt split or come away from the plenum.
Old Nov 27, 2006 | 12:22 PM
Dicko&Vacant
just had another check and its not where it goes into the fuel rail its where it goes into the inlet manifold itself
so prob still the same? the o ring?
Old Nov 27, 2006 | 12:27 PM
James_RScos's Avatar
James_RScos
Have you tryed removing it and reseating the oring and injector you can check the oring at the same time for faults
Old Nov 27, 2006 | 12:29 PM
Dicko&Vacant
will check that later, aint got time to remove it yet and have a good look
Old Nov 27, 2006 | 12:35 PM
SapphyMike's Avatar
SapphyMike
more than likely o-ring..
Old Nov 27, 2006 | 02:17 PM
Alps Pacino's Avatar
Alps Pacino
I might be able to get you an o ring if you tell me the size
Old Nov 27, 2006 | 05:14 PM
lawnsy's Avatar
lawnsy
think iv'e got a spare rubber down garage on set of yellows check the 10mm bolts that hold the fuel rail to the inlet and make sure one not come out or come lose and not keeping the injectors clamped in .....
Old Nov 27, 2006 | 06:57 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
thats what u get for trying to keep up with me.......laff i nearly bought a scooby...... nevermind whens our next adventure sunroof killer....
Old Nov 27, 2006 | 09:48 PM
Dicko&Vacant
haha you would of knew about it if i wanted to keep up with you anyway the speed you drive i couldnt afford to go anywhere else with ya lol
just need to get a sunroof now
Old Nov 27, 2006 | 09:53 PM
radiant red's Avatar
radiant red
dont think it should leak down there mate as that seal on inlet is for air and not fuel,can you post a pic?
s2 looks cool on siggy
Old Nov 27, 2006 | 10:06 PM
Dicko&Vacant
ill get a pic tomorrow as cars at my mams on her drive til i source a sunroof lol
and cheers, shame it dont run as well as it looks yours dont exactly look too shabby either
Old Nov 27, 2006 | 10:14 PM
radiant red
thanks but it aint seen road for over a year got to sell it.......so i can have 500 bhp
if you need an injector please pm me mate i can get very good prices,gotta be worth a try
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
