anybody good at auto electrics.
Old Nov 25, 2006 | 03:11 PM
fezzie2's Avatar
fezzie2
Default anybody good at auto electrics.
i have a fiesta with a series 1 turbo rngine installed, ive just bought it and there seems to be quite a few wlectrical problems with it, ive tried for days to sort it out but cant get anywhere. is anybody on here any good at this sort of thing or can reccomend a place that i can take it too. im getting so frustarted now as i really want to drive it. im based in lincolnshire.
thanks
Old Nov 25, 2006 | 03:13 PM
droptopRST's Avatar
droptopRST
You never said what electrical fault it was
Old Nov 25, 2006 | 03:20 PM
fezzie2's Avatar
fezzie2
well, theres a list.
when i got it, it was running fine. but it wouldnt hold charge over night, the battery keeps going flat. then i noticed that when you press the brake pedal the battery light comes on but the brakes dont, also when you press the heated rear windscreen light the battery light comes on. when you turn the lights on then it blows a fuse. i took the bulns out of the back lights and tried it, it stopped the battery lighht coming on, but now the car wont start, it will turn over but not kick in. so then i had a root through the wiring under the dash. didnt really do anything, but now wheni turn the ignition on the lights for the stack dash and fuel gauge come on but when i take the kets out of the ignition they stay on. also now when i connect the battery up the fuel pump starts priming and doesnt stop.
Old Nov 25, 2006 | 10:13 PM
b_kennedy's Avatar
b_kennedy
start from scratch. Get another loom
Old Nov 26, 2006 | 02:41 AM
fezzie2's Avatar
fezzie2
thats not a bad idea. i have a fiesta turbo loom kicking about, should i use that as a basis and work from there or what?
Old Nov 26, 2006 | 09:11 AM
b_kennedy's Avatar
b_kennedy
fiesta rs turbo loom is for an efi. A series 1 and 2 engine are mfi. The looms must match that engine or you will have problems. They may have left the fiesta loom in, and cut and joined loads to get it to run the escort engine. That may be causing you problems. Your fiesta loom will be fine but you might have to chnage a few bits on the engine to get it to run. Best person to speak to is safechav on here. He is a star when it comes to electrics, looms etc and has always got time to help someone
Old Nov 26, 2006 | 10:06 AM
DazC's Avatar
DazC
Thats some seriously fucked up electrics!
if i was you, i'd ditch the wiring loom and KE Jetronic. Fit the fiesta turbo loom and efi system. You would have to go about this as if you was converting an s1 to efi though.
Old Nov 26, 2006 | 10:19 AM
fezzie2's Avatar
fezzie2
your telling me, its frustrating to say the least, hahaha is it much of a job to get it to run on efi? would i have to change any parts of the engine like the metering head and pressure regulator etc?
Old Feb 12, 2007 | 04:04 PM
SafeChav's Avatar
SafeChav
Did you ever sort this
Sorry im a bit late lol
Old Feb 12, 2007 | 08:41 PM
b_kennedy's Avatar
b_kennedy
look who eventually joined the party
Old Feb 12, 2007 | 09:05 PM
SafeChav's Avatar
SafeChav
shut it you slag
Old Feb 12, 2007 | 09:39 PM
b_kennedy's Avatar
b_kennedy
Old Feb 12, 2007 | 10:19 PM
SafeChav's Avatar
SafeChav
Hows your car anyway Ben
"smoking" by any chance (absolutely no pun intended in any way/shape/form/cloud of smoke)
Old Feb 13, 2007 | 08:36 AM
b_kennedy's Avatar
b_kennedy
steering column is pukka
Old Feb 13, 2007 | 03:18 PM
SafeChav's Avatar
SafeChav
so..............you took that fag packet back out
Old Feb 13, 2007 | 10:22 PM
b_kennedy's Avatar
b_kennedy
no. its been bad wether here. I'll do it in the summer
Old Feb 14, 2007 | 06:22 PM
SafeChav's Avatar
SafeChav
I didn't ask you how the weather has been
Old Feb 14, 2007 | 08:13 PM
b_kennedy's Avatar
b_kennedy
I know but I wanted to tell you. That alright chav
Old Feb 15, 2007 | 02:01 PM
SafeChav's Avatar
SafeChav
cameron2
12
Sep 4, 2015 01:34 PM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
