Is Blue - Red - Black a S2 ecu?
Old Nov 25, 2006 | 02:47 PM
RapidRS's Avatar
RapidRS
Default Is Blue - Red - Black a S2 ecu?
As above, anyone who knows, I'd gratefully appreciate their knowledge.
Old Nov 25, 2006 | 03:54 PM
LEE-RS's Avatar
LEE-RS
Custom
yes its off s2
Blue-Red-Blue
Blue-Red-White
are off a s1 no knock sensor
Blue-Red-Black
Hearts & Diamonds
are off a s2 with knock sensor
Old Nov 25, 2006 | 04:49 PM
SafeChav's Avatar
SafeChav
Ooooooooohhh Lee aren't you such a clever boy
Old Nov 25, 2006 | 05:29 PM
RapidRS's Avatar
RapidRS
Originally Posted by LEE-RS
yes its off s2
Blue-Red-Blue
Blue-Red-White
Blue-Red-Black
Hearts & Diamonds
That'd explain why my S1 has been running like a bucket of cack since I've owned it then.
Hopefully the chipped Blue - Red - Blue ECU I now have will prove to be slightly better.
Old Nov 25, 2006 | 05:34 PM
SafeChav's Avatar
SafeChav
The ECU's are basically the same, if you connect a knock sensor to the current ECU you run, there should be no difference!
Remember if you change ECU it will need re-mapping though.......
Old Nov 25, 2006 | 07:47 PM
swerv's Avatar
swerv
the escort ECU's with knock sensor control are problem ones and definatly better off with the proper blue-red-blue ECU
there was quite a bit of difference when i changed from a chipped blue-red-black
Old Nov 27, 2006 | 08:57 AM
ivorbiggun's Avatar
ivorbiggun
You have to be very careful about this diagnosis. There's a very 'powerful' emporium just west of London who (some might say) developed a fairly uncanny 'knack' of making just such a diagnosis of this to justify a 'we can fix it but we'll have to put one of our chips in it /Ł175 pounds to you Sir approach'. Students of Fast Ford magazine will remember that they also trotted out that one to the journalist that took FF's project S2 there Last year.
If anyone does own an S2 and their tuner offers to 'rectify a fault' using the above old chestnut, at the very least get a second opion/ideally go and see
Jamie at Jamsport.
Old Nov 27, 2006 | 09:06 AM
ivorbiggun's Avatar
ivorbiggun
And as Andy says above there should be no difference in running an S2 ecu in a S1 as long as you've got a knock sensor connected.
JK12
33
Apr 26, 2021 12:09 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
rog
Sep 4, 2015 07:24 AM
Bailes1992
Sep 3, 2015 02:17 PM
3i Jim
Was It You?
Aug 1, 2015 06:33 PM
