Windows XP MBR HELP needed pls :(
OK
Heres my problem
I recently just did a fresh install of XP (same install disk as i always use
All was going well, have aquired sp1 on disk so put that on to save downloading it all, still going lovely, downloaded all the critical updates from the web, flying along now, and then i downloaded (from the MS update site) an update for the AMD K7 (am running a slightly clocked Athlon xp 2800), on reboot got the dreaded blue screen, computer shut down to prevent damage blah blah blah.
So try and restart it and wont even post proper, not detecting ide drives.
repeated attempts make no difference. Cleared the biosback to basic, now when booting all seems fine, well to detect ide's anyway, but after posting and when looking for os it says invalid or missing os.
Booted from cd fine, so thought well i aint got too much to reinstall anyway so will start from scratch.
Starts installing reformats (long method just to be sure ), copies files over and then wants to reboot, just as normal, only on reboot comes up with missing operating system error again, done this a couple of times with different install disks.
went into recovery console on install disks done a reformat from there, still the same afterwards.
Somehow (cant remember where now
possibly a 95 install disk) got partionmagic running and it reported partition error 110 and a MBR error, which it wouldnt do anything about fixing
, so went back into the xp recovery console and run fixboot and tried to reinstall xp again, no joy still same problem, then back into recovery console again and run fixmbr and still no joy
Anybody now if there a way to sort this or is drive total U/S as a boot drive now. Or as i have a nice new sata drive on order anyway, could this drive still be used for staorage (gutted at the thought of scrapping a 120gb drive totaly
) or recon it may be on its way out or more chance the windows update screwed the mbr somehow.
Any input REALLY appreciated, may take a while for me to reply as am on my laptop and depends when i can get on
Dont think i left too much out lol
Thanks
Mo
AKA Steve
Heres my problem
Thanks
Mo
AKA Steve
could really do with some ideas on this pls peeps, and am off to bed now so cant keep it up during the day
so if someone wouldnt mind BTTing it a couple times
for the clever people that live a normal life on the day shift, would be appreciated
Mo
aka Steve
Mo
aka Steve
hard disks are that cheap m8 a repair is unviable as when there fooked, they really are fooked. now go and put it in the bin.
get an old win95/98 bootdisk
do run fdisk and remove all partitions
then do fdisk /mbr
then try installing again
if it dont work aftr that, sorry you're fucked
then do fdisk /mbr
Isnt there a FIXMBR command on the recovery console?
had the same sort of problem once .. everything loaded fine .. then errors ... fitted a new hard drive .. all 100%
ordered it Sunday, just probs aint gonna get it before weekend due to bank holiday
then do fdisk /mbr
then do fdisk /mbr
will try the old 98 disk as u say as aint tried that yet
Right another question the new drive i ordered is a 200gb sata drive, have read conflicting reports about how to set this up as a boot drive, so expect to run into some probs there as well
point one is some people recon xp (when installing wont be sp1) wont see above 150gb so will have to partition it first do you guys know if this is correct, point b do i have to hit the f6 key on install to install drivers for it as i got a set up disk with my mobo, but that says for sata RAID and i aint setting up raid just one sata disk, point c do i have to set the boot order in bios to scsi (spose will depend on mobo as may have an option to select sata no matter how it runs it, just aint looked yet since ordering new drive Mo
aka Steve
just go thru the normal motions... and make the normal partition as big as possible... (as big as the setup program will let you... take the defaults make sure you format it as NTFS and NOT FAT32
then any left over un-partitioned space, set that up AFTERWARDS (control panel, administrative tools, computer managed, storage devices)
or do what i do... DONT BOTHER
leave the unpartitioned space there and only bother to partition it if you actually even NEED it... as it confuses me having more than one drive/partition on my PC... lol
good point about leaving it alone (unpartitioned)
actually did a speed test of a drive i partitioned once and slowed the main drive down a bit but the second partition (drive) was a lot slower, dont understand why this happened tbh, but was on my laptop (compaq) running something called speedsys or something (for when running on batteries and or power consumption i think) maybe that why
Anyway borrowed a drive off a mate now so just gonna try and do a basic install (if the win 98 disk dont work) just to check there aint some silly setting in my bios i missed
or anything worse
Mo
aka Steve
Mo
aka Steve
had another though m8. did you purchase the drive your self or was it in ya pc when ya got it? if you got it yourself or your pc IS NOT main brand like DELL etc you should have a 3year manufacturers warrenty. you can check this on the web by going to the manufacturers web site and checking the serial number. pm me if your stuck. cheers. adz.
JoeyBoyden
Jan 4, 2024 02:36 PM
borboyous
Aug 22, 2015 11:17 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
