ERST PROBLEM
Old Nov 21, 2006 | 10:39 PM
Maxxeh's Avatar
Maxxeh
Default ERST PROBLEM
I thought i had a fuel pump problem. But now that i have changed it, it seems to be worse the car tries to start very slowly, but never does.
If the fuel relay was fockered, would the car start at all?
What other things can it be???
Old Nov 21, 2006 | 11:13 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Does it turn over normal, or very slow?
Old Nov 21, 2006 | 11:15 PM
Maxxeh's Avatar
Maxxeh
very very slow
Old Nov 21, 2006 | 11:53 PM
vroooom ptssssh
It Wasnt Me!
Common problem, starter motors cooked from the heat off the turbo!
after a while of getting hot/cold/hot/cold they dry out inside, nothing much you can do apart from fit the original heat shield or keep replacing them!
Also makesure the battery is charged and all leads are tight onto it and the starter. someone will post up what voltage you should see when turning the engine over just to makesure the starter is getting enough power.
Old Nov 23, 2006 | 08:53 PM
Maxxeh's Avatar
Maxxeh
cheers
Old Nov 23, 2006 | 09:59 PM
vroooom ptssssh
It Wasnt Me!
No prob, let us know how you get on
Old Nov 24, 2006 | 10:34 AM
bassboy's Avatar
bassboy
sorted max? if not book it in and ill sort all your problems out with it LOL
bassboy
Old Nov 24, 2006 | 03:41 PM
Maxxeh's Avatar
Maxxeh
aint sorted yet. BUT gambit is hoooooookkkkkin it up
Old Nov 24, 2006 | 07:06 PM
SafeChav's Avatar
SafeChav
Try getting a starter motor off a cmaller engines CVH, they still work fine but are smaller so it wont be as close to the down pipe.
Mines off a 1.4
Old Nov 24, 2006 | 08:59 PM
Rick's Avatar
Rick
Mines off a 1.4
AT LAST SOMEONE WITH SENSE!!!
The RST is a LOW COMPRESSION engine. You can turn it over with the stater from go kart...... My fiesta 1.1 starter has NEVER given me any trouble.
Old Nov 24, 2006 | 09:59 PM
T28 RST's Avatar
T28 RST
Ok then
Dont know what model my starter is but its the shortest one they could give me as my down pipe sat less than 1" from the original starter
Old Nov 24, 2006 | 10:27 PM
SafeChav's Avatar
SafeChav
Its not just length, the smaller starters are also a lot smaller diameter. RS Turbo starters are un-necessarily FUCKING MASSIVE
Old Nov 25, 2006 | 11:23 AM
gambit's Avatar
gambit
Default starter motor
i have given maxxeh a starter now and original heatshield, the starter has proved very reliable to me so i think he should be fine
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
