Running Problem with Series 2 ***SORTED***
Old Nov 18, 2006 | 06:45 PM
PeteS2RST's Avatar
PeteS2RST
Default Running Problem with Series 2 ***SORTED***
My brothers been having trouble with his series 2:
about a week ago it started running a bit lumpy as if it was only running on three and then it stopped altogether. the engine would turn over and there is definitely a spark but doesn't seem to be getting fuel theres good pressure before and after the fuel filter and also going into the metering head but no pressure at the injectors except for the cold start valve
any ideas
Cheers in advance
Pete
Old Nov 18, 2006 | 08:07 PM
Maxxeh's Avatar
Maxxeh
does it cut off?
Old Nov 18, 2006 | 08:17 PM
PeteS2RST's Avatar
PeteS2RST
Cut what off ???
Old Nov 18, 2006 | 09:04 PM
addiction's Avatar
addiction
you wont get pressure at the injectors unless you push the flap in the metering head down as you crank the engine over.
Old Nov 19, 2006 | 09:17 AM
GUZZLER's Avatar
GUZZLER
could be a metering head problem, remove the airfilter & tap the air flap while your brother is turning it over.
Old Nov 19, 2006 | 10:25 PM
SafeChav's Avatar
SafeChav
If you cant get any fuel out of the injectors with the fuel pump running and the flap depressed the chances are that the pump is weak and isn't creating ENOUGH pressure.
Old Nov 21, 2006 | 10:00 PM
PeteS2RST's Avatar
PeteS2RST
All sorted cheers to all those who posted
Old Nov 21, 2006 | 10:01 PM
SafeChav's Avatar
SafeChav
come on then, share it with us
Old Nov 22, 2006 | 10:59 AM
PeteS2RST's Avatar
PeteS2RST
Turned out to be plugs. spark he was getting wasn't that great after all
marky_g
18
Aug 26, 2015 03:42 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
dlwarrior
Aug 5, 2015 10:19 AM
