cosworth fuel pump on frst idle problems helllllp
Old Nov 17, 2006 | 01:53 PM
turbo tongey's Avatar
turbo tongey
Default cosworth fuel pump on frst idle problems helllllp
i have fitted a 195 bhp powerchip ofab and Beige injectors and a escort cosworth fuel pump and a -31 but the car will not idle properley.But when i put the standard frst fuel pump back on it idles well i have not got a clue why please help
Old Nov 17, 2006 | 03:30 PM
SafeChav's Avatar
SafeChav
I expect your fuel pressure regualtor needs adjusting as the cossie pump will be delivering the fuel faster and at a higher pressure.
Chances are its over- fuelling at idle
Old Nov 17, 2006 | 05:32 PM
turbo tongey
Default frst idle problems
where is the fuel pressure regualtor placed in the engine bay
Old Nov 17, 2006 | 07:30 PM
Alvyn's Avatar
Alvyn
Default Re: frst idle problems
as you look from the front it WILL be at the right hand side at the end of fuel rail silver/grey in colour it may still have the seal in the middle(will have to remove that and use an allen key to adjust)
Old Nov 17, 2006 | 07:49 PM
turbo tongey
Default fuel pressure regualtor
thanks
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
