trickle chargers
Old Nov 12, 2006 | 03:27 PM
swerv's Avatar
swerv
Default trickle chargers
does anyone use these?
im thinking of getting one but unsure wether to leave it on all the time in case of fire or anything like that?
am i better off just buying a jump starter?
Old Nov 12, 2006 | 05:33 PM
Use one on mine ,once it gets to the charge level it shuts off and starts up when the battery level drops again
Old Nov 12, 2006 | 06:26 PM
dave green's Avatar
dave green
I use a 4 Amp charger . Have it on a timer. 6 hours a day
Dave
Old Nov 12, 2006 | 07:24 PM
Wardy257's Avatar
Wardy257
Get an optimate, they can be left on for up to 2 years and have all the safety stuff built in.
Old Nov 12, 2006 | 07:32 PM
SafeChav's Avatar
SafeChav
IF the car lives outside you want to be getting a solar panel one
If not as said, you want to spend a few pennies and get a good one with peak detection, otherwise you won't be doing the battery any good.
Old Nov 12, 2006 | 09:55 PM
MM_RACING's Avatar
MM_RACING
Hi m8
I use the following
http://www.airflow-uk.com/battery-conditioner.htm
Old Nov 29, 2006 | 08:09 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
I got mine from an old Ford garage in horncastle for aroud Ł15. It looks like a mobile phone charger, but has croc clips on the end. Built in shut-off as standard and I leave mine fitted most of the time. Well worth it & doesn't knacker your battery like continous discharging & jump starting can.
Old Nov 29, 2006 | 09:05 PM
BillyCabrio's Avatar
BillyCabrio
I have a Draper one from Halfords, can't fault it
Old Nov 29, 2006 | 11:44 PM
gaz s1's Avatar
gaz s1
im confused do you have to have a mains connection as my garage is away from the house im probably being thick
Old Nov 30, 2006 | 12:13 AM
SafeChav's Avatar
SafeChav
Can't have a charger without a supply
Old Nov 30, 2006 | 08:59 AM
ivorbiggun's Avatar
ivorbiggun
Take a look at machine marts AC70 Ł30 for an 'intelligent' charger ie once fully charged it automatically switches to trickle
www.machinemart.co.uk/product.asp?p=010316200
Old Nov 30, 2006 | 05:03 PM
BillyCabrio
YODI
Aug 29, 2015 05:48 PM
DOO
27
Nov 27, 2005 09:11 AM
RS Bowk
22
Sep 30, 2005 10:52 PM
3DOOR ARY
Mar 13, 2005 08:36 PM
Simbo
Ford Escort RS Cosworth
Jan 28, 2004 08:28 PM
