oil pump for saff.. high pressure??
Old Nov 5, 2006 | 01:30 PM
RS-adam's Avatar
RS-adam
Default oil pump for saff.. high pressure??
hi there...
My friend are currently rebuilding his buttom end for his 4x4 saff... wit std cosworth pistons and bearings... but he wanted me to ask you guys if there would be any advangedes in buying a highpressure oil pump insted of using the std oil pump?
the spec is:
std head, wit venier pulley
Light blue injectors
mongoose
RS 500 I/C
GT 30R rollerbearing turbo
cheers
Old Nov 5, 2006 | 03:45 PM
jon@work's Avatar
jon@work
standard pump will be fine, unless he's using a sandwich plate and oil cooler radiator, in which case a high pressure pump would be better
Old Nov 5, 2006 | 10:54 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Mine runs like this with a standard pump and had no problems with oil pressure, been like it for 9 years now
Steve.
Old Nov 6, 2006 | 12:26 AM
jon@work's Avatar
jon@work
Steve.
I've been told that a oil cooler kit will reduce the oil pressure, so either you must have a good un-worn standard pump, or you're basing your reply on not seeing the standard oil pressure light go on, which is at an unfeasibly low pressure that won't save your engine by the time it lights up (and not viewing the actual oil pressure on a gauge) ? (a query, not a dig)
Old Nov 6, 2006 | 07:54 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Steve.
I have a capilary oil gauge and when at hot idle i have 34psi.
Hot running is 50psi.
Steve.
Old Nov 6, 2006 | 10:27 AM
jon@work's Avatar
jon@work
fair enough - standard pump sounds fine then, oil cooler or not
Old Nov 6, 2006 | 12:41 PM
cosrep's Avatar
cosrep
Sorrry for hijacking the post here but does anyone know the what pressure both pumps create in an otherwise standard engine?
Old Nov 6, 2006 | 02:08 PM
RS-adam's Avatar
RS-adam
sandwich plate.. please explain mate
tanx for the replys.. I'll tell my mate
Old Nov 6, 2006 | 05:16 PM
jon@work's Avatar
jon@work
Sandwich (take-off) plate with separate oil cooler rad (thus cooling oil by air flow) replaces the standard modine (oil/water cooler) that sits between the block and the oil filter. Useful for lower oil temps on track cars.
Old Nov 7, 2006 | 03:35 AM
TurboFlush's Avatar
TurboFlush
I get like 41psi at 1,000 rpm w/ oil cooler sandwich, remote larger filter. no probs.
all the stuff makes it a pain to check oil though as it all drains back into the motor fairly quick.
at about 200rpm I get 20 psi. LOL
TF
Old Nov 7, 2006 | 08:39 PM
radiant red's Avatar
radiant red
TF
thats heck of a lot mate,im getting (hot engine)28 psi idle and 60 psi 2500+ using a graham goode uprated pump and a very fresh engine running 15 50 mobil 1
Old Nov 7, 2006 | 09:00 PM
TurboFlush's Avatar
TurboFlush
whats your idle at? ... I think its psi... it is a race tech gauge, so maybe it reads something other than psi.
TF
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
