XR 4x4 MT75 4x4 to 5 litre V8 conversion
Old Nov 4, 2006 | 09:16 PM
Mark V8's Avatar
Mark V8
Default XR 4x4 MT75 4x4 to 5 litre V8 conversion
This is going to be a long running project as I'm short on spare time at the moment
The first part of the jigsaw is made, a 16mm thick aluminium adaptor plate to mate a Ford 302 to a MT74 4x4 box.
Flywheel is still to be made as well as sorting out a sump/diff arrangement.
Mark
Old Nov 4, 2006 | 09:40 PM
richard_syko's Avatar
richard_syko
Nice work.
How many blades you go through cutting that thick
Old Nov 4, 2006 | 09:57 PM
Mark V8's Avatar
Mark V8
Originally Posted by richard_syko
Nice work.
Having a CNC machining centre at work is a big help
Mark
Old Nov 4, 2006 | 10:09 PM
richard_syko
Nice work.
Mark
Thought I read you did it with a jigsaw
Old Nov 4, 2006 | 11:32 PM
mark's Avatar
mark
intresting
where are you putting the front difff?
Old Nov 5, 2006 | 08:19 AM
Mark V8's Avatar
Mark V8
Originally Posted by mark
intresting
In the original 2.9 V6 position, I'm going to cut and shut a 4x4 sump to fit the 302 block the sump will need to be moved back by 16mm to allow for the thickness of the adaptor plate so the front prop is the right length.
Mark
Old Nov 5, 2006 | 09:48 AM
Tomasberkut's Avatar
Tomasberkut
Arent you afraif your car will be nose heavy ?
I am also in the middle of putting a V8 lump in the front of my Sierra XR4X4, with the cologne V6 the car has a awfully heavy nose, the understeer is acting really badly..
You are installing a big iron Ford V8 in the place of a already heavy engine... are you prepared the car will handle really bad ?
Maybe you should consider a lighter rover V8 engine or go a little more modern, BMW, MB, Nissan, Toyota. I choose Toyota, after some lightening i have a 166kg engine insted of the stock 270kg of old cologne iron rust. I am starting with 280bhp stock, ready to be blown or revved hard for much more...
Old Nov 5, 2006 | 12:58 PM
Mark V8's Avatar
Mark V8
I will have to put up with the handling, the Ford 302 is the lightest of the iron V8 engines and I may be able to get some aluminium heads etc to keep the weight down.
The problem with every alloy V8 I've looked at is the fact that the casting extends down too far below the CL of the crank meaning the front diff will hit the block
I started off with a 3.9 Rover V8 but that was no good.
The Toyota/Lexus no good.
Audi V8 no good.
LS1 no good and way out of my budget.
The 302 extends only around 3mm below the crank CL, the Rover v8 around 57mm.
Mark
Old Nov 6, 2006 | 09:59 AM
mark's Avatar
mark
good luck with it m8
Old Nov 6, 2006 | 10:26 AM
Tomasberkut
I see the problem Mark but there is a solution with the Toyota V8. The differential, when the oil pan is properly made will sit on the side if the engine. The oil pan flange is narrow, much more narrow than the V6 cologne. Whats more important there is no offset present in the V6.
Take a look here, here and here.
Aluminium heads would be sweet, thats a big weight gain and a lot to offer in handling.
Will you be using a custom made flywheel ? Judging by the flange yes.
Old Nov 6, 2006 | 08:07 PM
Mark V8's Avatar
Mark V8
I got as far as chopping up the sump when trying the Rover engine and did not consider engine width at the bottom when looking into alternatives At least the 302 is very cheap to tune
IF this web site is correct the 302 weighs in at 209KGs
http://www.geocities.com/infieldg/v8enginesizes.html
Aluminium heads, tubular headers ect should get some weight off.
My next job is to make a flywheel that will take the 2.9 ring gear and Cosworth clutch.
How far have you got with the Toyota V8 conversion, any more pics ?
Mark
Old Nov 6, 2006 | 08:37 PM
costina's Avatar
costina
Live long and prosper!!
Good luck Mark nice to see some different thinking.
British engineering at its best (in the garage)
Old Nov 6, 2006 | 09:00 PM
Mark V8's Avatar
Mark V8
Thanks for the comments, the prices of parts for the 302 are so cheap it's unreal. Check out some of the prices here
http://stores.ebay.co.uk/1AAA1-The-Mustang-Depot
I can see a nice set of big valve aluminium heads eating up my Christmas club money
Mark
gcfcos
59
Oct 6, 2015 05:04 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Iain Mac
Sep 30, 2015 09:39 PM
mpilk
Sep 27, 2015 09:21 AM
