xr2i immobiliser problem need help!
Old Oct 30, 2006 | 05:33 PM
xr2i-lee's Avatar
xr2i-lee
Default xr2i immobiliser problem need help!
Hi guys! basically, its been in my garage for a few weeks, (without a battery on dont know if this makes and difference) always started up first time when i put a battery on, and then yesterday i went to start it and i couldn't get the immobiliser off, im not sure if immobilisers come standard on xr2i's (1992).
i dont know the make of it off the top of my head, and i dont have the red chip in the key.
and ideas on how to disable it so i can get it started?
thanks
Old Oct 30, 2006 | 07:26 PM
SafeChav's Avatar
SafeChav
Xr2i's never came with an immobiliser as standard im aware of.
What makes you think it has an immobiliser if you dont have a coded key?
Old Oct 31, 2006 | 12:27 AM
xr2i-lee's Avatar
xr2i-lee
because i have a keyfob, and you can usually turn the immobiliser on and off, but for some reason it wont turn off.
there is a little red light on top off the steering column, it goes off when the immobiliser is off. stays on when the immobiliser is on etc.
Old Oct 31, 2006 | 11:01 AM
MikeyXR2i's Avatar
MikeyXR2i
It must be something someone's fitted after, as they never had no security on them when new. I would put a good charged battery on the car, also make sure the battery in the key fob aint dead, as if it is, the keyfob aint gonna work. What make system is it?
Old Oct 31, 2006 | 11:27 AM
SafeChav's Avatar
SafeChav
What sort of fob is it? One you have to push in and de-activate, or like the newer style ones where it just detects the fob is within range?
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Andypandy260
Sep 23, 2015 10:28 PM
