HELP!!! S2 is backfirin (not solved, still doin it)
Old Oct 29, 2006 | 03:42 PM
rsdan's Avatar
rsdan
Default HELP!!! S2 is backfirin (not solved, still doin it)
can anyone help me. the engine has just been rebuilt, 1.8 zetec bottom end. its fine when u 1st start it but when it gets warm it starts to backfire
cheers
Old Oct 29, 2006 | 03:58 PM
turboash's Avatar
turboash
Default back fire
i have drove the car and it only happens once warm and as it is coming on boost,
Old Oct 29, 2006 | 04:32 PM
5axo.rst's Avatar
5axo.rst
Could possibly be distributor, mine did the exact same thing, put a new dizzy on and its been fine!
Could check usual things like plugs, leads, coil etc...
Old Oct 29, 2006 | 06:22 PM
matt p's Avatar
matt p
As above 99% sure its your dizzy mate.
Source a new one and let us know how you get on.
Could be a few other things but pretty sure its that.
Cheers matt
Old Oct 29, 2006 | 07:15 PM
Šhatter Box's Avatar
Šhatter Box
go efi it will make all ur troubles go
Old Oct 29, 2006 | 07:16 PM
DazC's Avatar
DazC
Could be your dizzy as advised. The heat can affect the sensor causing the signal to break down.
Old Oct 29, 2006 | 08:48 PM
rsdan's Avatar
rsdan
wud love to, not as easy as that tho. think ive spent enough on her for a mo. or ave i lol
Old Oct 29, 2006 | 08:49 PM
rsdan's Avatar
rsdan
cheers guys, i will try and source a new dizzy and will let u no.
Old Oct 30, 2006 | 06:11 AM
HORNETS7's Avatar
HORNETS7
well personnaly i would have thought it was a sensor!
make sure uve got the correct plug on right at the back of the inlet manifold!!!
when on boost it can be the charge air sensor
also there is a temp sensor as well think it either he brwon one or the yellow one!
Old Oct 30, 2006 | 12:48 PM
SafeChav's Avatar
SafeChav
I can almost guarantee it won't be any of them.....distributor as everyone else has said!
A dead give away is the rev counter going tits when it back fires
Old Oct 30, 2006 | 07:41 PM
HORNETS7's Avatar
HORNETS7
hmm he doesn't say owt about the rev counter going funny?
just says backifiring when warm and on boost
coule even be blowing out spark when boosting try checking t he sparkplug gap!
Old Oct 30, 2006 | 10:41 PM
rsdan's Avatar
rsdan
think i mite ave found out the problem............
was drivin the car earlier, 1st time in 2 years (oh it felt good to be bk) and the car lost all power, lights etc. fukin alternator belt broke . there i am stuck on the dual carridgeway, pitch black wiv no lights or hazard lights, i was shitin myself. anyway my mate came to my rescue wiv a new belt and the back firin seems to ave stoped, will c if it does it tomorrow wen i take it for a spin...........
cheers for all the help guys
Old Oct 31, 2006 | 12:44 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Old Oct 31, 2006 | 11:31 AM
SafeChav's Avatar
SafeChav
I take it you remember what that red light that was glowing the whole time is for now then
Old Oct 31, 2006 | 06:25 PM
turboash's Avatar
turboash
Default misfire
But the light was only on once the belt had snapped then minutes later the engine cut out, so was only glowing for minutes, yet its been backfiring for days
Old Oct 31, 2006 | 06:26 PM
SafeChav's Avatar
SafeChav
Ah fair enough then
personally though i wouldnt say that bares any relevance to the back firing.
Old Nov 2, 2006 | 10:29 PM
rsdan's Avatar
rsdan
guna change the plugs and leads on the wk end and c if that sorts it.
Old Nov 2, 2006 | 11:06 PM
Rick's Avatar
Rick
You say coming on boost? It could well be a fuel enrichment problem.
Old Nov 3, 2006 | 01:01 PM
SafeChav's Avatar
SafeChav
Is the rev counter going doolally when it back fires?
Old Nov 3, 2006 | 05:32 PM
rsdan's Avatar
rsdan
avnt checked that, will do if it does it 2moz, which it will.
Rod-Tarry
237
Mar 18, 2016 09:13 PM
cossirob
Sep 16, 2015 07:39 PM
dms04
Sep 11, 2015 01:57 PM
nick8saff
Aug 16, 2015 05:35 PM
