Problem with XR3i,Fuel pump cuts out when warm,please help
Old Oct 28, 2006 | 10:46 PM
Dog-i's Avatar
Dog-i
Default Problem with XR3i,Fuel pump cuts out when warm,please help
Hi i'm new here,I have a Mk3 xr3i and have been having problems with the fuel pump cutting out when the car is warm.It starts and runs fine but when i turn the engine off after a 10-20min run and try and start it again the fuel pump stops running.Then if i leave it a few minutes it will start again.Can anyone help please!!!!!!!
I have replaced the fuel pump,ignition module and coil.
Could it be the fuel pump relay? If so could someone please tell me where abouts it is because i dont think its in the fuse box.
thanks again
Old Oct 28, 2006 | 11:31 PM
NUTS RuS's Avatar
NUTS RuS
Are they under the steering column somewhere ?
Oh and welcome to Pf
Old Oct 29, 2006 | 03:44 PM
Dog-i's Avatar
Dog-i
Thanks for that,i've found it now i'm guessing its the tall purple relay.I'll try that next! lol
Old Oct 29, 2006 | 07:09 PM
foywhit's Avatar
foywhit
Default fuel pump cuts out
it is more yhan likely you relay and will cost around Ł20 for a new one, you will find it located behind the dash either by the passenger or drivers door and it is a violet (purple) colour however if its a mk3 and that dont work try the black module thet sits along side it it is slightly wider and thiner than the average relay if you need any more advice eithr email me or leave a message on site. Carl.
Old Oct 30, 2006 | 06:15 PM
Dog-i's Avatar
Dog-i
Thanks I've got one on order Ł15+vat i just hope it solves it.Thanks again for your help.
Old Oct 30, 2006 | 07:28 PM
SafeChav's Avatar
SafeChav
I would of said the ignition module from the type of fault but you have replaced that, lets hope its the relay
Old Oct 30, 2006 | 08:41 PM
Dog-i's Avatar
Dog-i
Cheers anyway,ignition module was my first thought.I'm on my 7th mk3 XR3i and 4 of them has needed one.
Another quick question: The ignition module has 3 wires from the multi plug green,black and brown.The brown earth wire is not conected to anything and is just hanging down,is it supposed to go to the distributor somewhere or was it for those distributors with a metal cover round them?
Old Oct 31, 2006 | 11:36 AM
SafeChav's Avatar
SafeChav
What year is the car and what dizzy do you have? Blue cap or black cap?
Old Oct 31, 2006 | 01:22 PM
Dog-i's Avatar
Dog-i
Its an 83 Y reg and its got the distributor with the black cap.I Seem to remember one of my other xr3i's having a metal cover around the cap that had an earth on it,i think it was the blue cap distributor though.
Old Oct 31, 2006 | 01:25 PM
SafeChav's Avatar
SafeChav
If its a black cap it should have 3 wires on the multi plug and all of them need to be connected! I thought the early cars all had blue cap
Where does this wire come from exactly? Can you get a picture?
Old Oct 31, 2006 | 01:56 PM
Dog-i's Avatar
Dog-i
The wire comes out of the black multi plug that go's on the amplfier module screwed to the top of dizzy.Theres the 2 green and black wires that go to the coil and the brown wire.Its about 4" long and has a white spade end on it.
Sorry couldn't get a picture.
Old Oct 31, 2006 | 01:58 PM
SafeChav's Avatar
SafeChav
The brown wire in the plug should definately have an earth continuity if you are running a black cap.
A WHITE spade end? Does it look factory? Has it always been disconnected?
Old Oct 31, 2006 | 02:05 PM
Dog-i's Avatar
Dog-i
Yeah the spade end is factory its sealed to the wire.Yeah its always been disconnected the car runs fine as it is.
Oh and i've just fitted the fuel pump relay and its fixed it Yipee!! it's running perfect now.
Old Oct 31, 2006 | 02:06 PM
SafeChav's Avatar
SafeChav
wasting my time
lol
Old Oct 31, 2006 | 02:08 PM
Dog-i's Avatar
Dog-i
Ha ha,Yeah i think i'll leave well enough alone.Cheers for your help anyway.
Old Oct 31, 2006 | 02:10 PM
SafeChav's Avatar
SafeChav
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
