Modified 2WD Sump to accept oil return from Bailey Breather
Old Oct 28, 2006 | 06:46 PM
Daxcossie's Avatar
Daxcossie
Default Modified 2WD Sump to accept oil return from Bailey Breather
Im having a sump modified to accept the oil return from a Bailey breather tank and I was just wondering what side I should have the return on the sump fitted. Plenum or turbo side ?
Im also having an oil temp sender fitted to the sump at the same time.
Any advice or photos would be great
Old Oct 29, 2006 | 09:42 AM
cossie604's Avatar
cossie604
For what reason chap?? Theres a blanking plug in the block at the back below the exhaust manifold thats drains straight back into the sump The Bailey breather kit should contain a threaded adaptor to fit said hole.
Old Oct 29, 2006 | 09:44 AM
rapidcossie's Avatar
rapidcossie
the return needs to be under the oil level in the sump.
Old Oct 29, 2006 | 09:52 AM
Daxcossie's Avatar
Daxcossie
Im breathing from both sides of the block and returning oil to the sump, where there is no pressure to restrict the oil returning. If you speak to Bailey they in fact recomend this, but its a pain taking the sump off and having it modded, so they make do with returning the oil to the crank etc.
But, I stll want to know what side of sump to have the return running too ?
Old Oct 29, 2006 | 09:54 AM
rapidcossie
makes no diff mate..
you can get adaptors that let you return via a special sump plug...
Old Oct 29, 2006 | 04:31 PM
Mark_1's Avatar
Mark_1
use plenum side, as the heat from the exhaust will detoriate the return hose if you have it on the turbo side.
Old Oct 30, 2006 | 06:26 AM
Daxcossie's Avatar
Daxcossie
Great stuff.
Ill get it placed on the plenum side.
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
kevin36
Sep 2, 2015 06:24 PM
FlashRS
13
Aug 31, 2015 06:02 PM
